Some adapters must be placed in specific Peripheral Component Interconnect (PCI), Peripheral Component Interconnect-X (PCI-X), or PCI Express (PCIe) slots to function correctly or to perform optimally. Use this information to determine where to install PCI adapters.
Figure 1 shows the back view of the system unit with the location codes for the PCI and GX+ slots. Table 1 describes the slots. Each PCI-X DDR or PCIe slot is a separate PCI host bridge (PHB).
| Slot number | Location code | Description | PHB | Adapter size |
| Slot 1 | P1-C1 | PCIe 8x | PCIe PHB0 | short |
| P1-C7 | GX+ or GX++ | |||
| Slot 2 | P1-C2 | PCIe 8x | PCIe PHB1 | short |
| P1-C8 | GX+ | |||
| Slot 3 | P1-C3 | PCIe 8x | PCIe PHB3 | long |
| Slot 4 | P1-C4 | PCI-X DDR, 64-bit, 266 MHz |
PCI-X PHB0 | long |
| Slot 5 | P1-C5 | PCI-X DDR, 64-bit, 266 MHz |
PCI-X PHB1 | long |
I/O expansion units are used to increase the maximum number of adapters that the 8204-E8A can support. Expansion units 5796, 7311-D20 and 7314-G30 are supported on systems running AIX® or Linux® operating systems. The system can be configured to support up to twelve I/O expansion units. Feature 5796 is the current feature code for the expansion unit that in the past was identified as a 7314-G30. For the remainder of this section, only the 5796 feature code is used when referring to that expansion unit.
A 2-core system supports either one 12x Channel Adapter or one RIO-2 adapter. A 4-core to 8-core system supports two 12x Channel Adapters, or two RIO-2 Adapters, or one 12x Channel Adapter and one RIO-2 adapter.
5796 expansion units attach to a 12x Channel Adapter installed in one or both of the two GX slots available in the system unit. A 2-core system supports one 12x Channel Adapter with up to 4 drawers attached. A 4-core to 8-core system supports two 12x Channel Adapters, with up to 4 drawers attached to each adapter.
7311-D20 expansion units attach to a RIO-2 Adapter installed in one or both of the two GX slots available in the system unit. A 2-core system supports one RIO-2 Adapter with up to six drawers attached. A 4-core to 8-core system supports two RIO-2 Adapters, with up to six drawers attached to each adapter.
7311-D20 I/O drawers with RIO Ports to I/O Planar Riser Card (#6413) must be upgraded to RIO-2 Ports to I/O Planar Riser Card (#6417) before they can be attached to a System p® server with POWER6™ processors.
Some I/O adapters supported in the 7311-D20 I/O drawers when attached to a System p5® server will not be supported when attached to an System p server with POWER6 processors. See Adapters supported on AIX, IBM i, and Linux for more information on supported adapters.
Expansion unit models 0588, 0595, 5094, 5096, 5294, 5296, 5790, and 5796 are supported on systems running the IBM® i operating system.
PCIe expansion units 5802 and 5877 are supported on the system running AIX, IBM i, or Linux operating systems. The system can be configured to support up to four I/O expansion units.
The expansion units attach to a 12X Channel Adapter installed in one or both of the two GX slots available in the system unit.
The 8204-E8A supports up to four POWER6 processor cards with 2-core, 4-core, 6-core, and 8-core configurations. Unless otherwise noted in the tables that follow this list, the maximum number of adapters allowed are shown in this list:
Use this information to identify slot placement priorities. Unless otherwise noted in the table, the maximum number of adapters supported is listed in Maximum number of adapters supported. In the following table, adapters are sorted in descending order by priority. The highest priority adapters are first in the table.
| Feature | Description | System unit slot priority | Maximum number of adapters supported |
| 63121 | Quad Digital Trunk Telephony PCI Adapter | 4, 5 | 2 per system |
| 5721** | 10 Gb-SR Ethernet PCI-X 2.0 DDR Adapter | 4, 5 | 32 per system |
| 5722** | 10 Gb-LR Ethernet PCI-X 2.0 DDR Adapter | 4, 5 | 32 per system |
| 5719** | 10 Gigabit-LR Ethernet PCI-X Adapter | 4, 5 | 32 per system |
| 5718** | 10 Gigabit-SR Ethernet PCI-X Adapter | 4, 5 | 32 per system |
| 5776** | PCI-X Disk Controller - 90 MB | None |
| 5777** | PCI-X Dual Channel Ultra320 SCSI RAID Adapter | None |
5778** |
PCI-X Dual Channel Ultra320 SCSI RAID Adapter with Auxiliary Write Cache (double-wide) | 4, 5 |
| 5760** | PCI-X Fibre Channel Disk Controller | None |
| 5761** | PCI-X Fibre Channel Disk Controller | None |
| 5749** | 4 Gigabit Dual-Port Fibre Channel PCI-X 2.0 DDR Adapter | 4, 5 |
| 5904** | PCI-X DDR 1.5 GB cache SAS RAID Adapter | 4, 5 | 49 per system |
| 5908** | PCI-X DDR 1.5 GB cache SAS RAID Adapter | 24 per system | |
| 5900** | PCI-X DDR Ext Dual-x4 3Gb SAS Adapter | 4, 5 | 58 per system |
| 5902** | PCI-X DDR Ext Dual-x4 3Gb SAS RAID Adapter | 4, 5 | 60 per system |
| 5912** | PCI-X DDR Dual-x4 3Gb SAS Adapter | 4, 5 | 60 per system |
| 5759** | 4 Gb Dual-Port Fibre Channel PCI-X 2.0 DDR Adapter | 4, 5 | 50 per system |
| 5740** | 4-Port 10/100/1000 Base-TX PCI-X Adapter | 4, 5 | 32 per system |
| 5712* | PCI-X Dual Channel Ultra 320 SCSI Adapter | 4, 5 |
| 5707* | 2-Port Gigabit Ethernet-SX PCI-X Adapter | 4, 5 | 64 per system |
| 5706* | 2-Port 10/100/1000 Base-TX Ethernet PCI-X Adapter | 4, 5 | 64 per system |
| 5704* | PCI-X Fibre Channel Tape Controller | None |
| 5702* | PCI-X Ultra Tape Controller | None |
| 5701* | 10/100/1000 Base-TX Ethernet PCI-X Adapter | 4, 5 |
| 5700* | Gigabit Ethernet-SX PCI-X Adapter | 4, 5 |
| 5758* | 4 Gb Single-Port Fibre Channel PCI-X 2.0 DDR Adapter | 4, 5 | 50 per system |
| 5713* | 1 Gigabit-TX iSCSI TOE PCI-X Adapter | 4, 5 | 42 per system |
| 5714* | 1 Gigabit-SX iSCSI TOE PCI-X Adapter | 4, 5 | 42 per system |
| 5716* | 2 Gigabit Fibre Channel PCI-X Adapter | 4, 5 | 58 per system |
| 5736* | PCI-X DDR 2.0 Dual Channel Ultra320 SCSI Adapter | 4, 5 | 58 per system |
| 5806* | PCI-X DDR 2.0 Dual Channel Ultra320 SCSI Adapter | None |
| 2780* | PCI-X Ultra4 RAID Disk Controller | None |
| 2757* | PCI Ultra RAID Disk Controller | None |
| 2787* | PCI-X Fibre Channel Disk Unit Controller | None |
| 5580* | 2780 Controller with 5708 Auxiliary Write Cache | None |
| 5581* | 2757 Controller with 5708 Auxiliary Write Cache | None |
| 5583* | 5738 Controller with 574F Auxiliary Write Cache IOA | None |
| 5590* | 2780 Controller with 574F Auxiliary Write Cache IOA | None |
| 5591* | 2757 Controller with 574F Auxiliary Write Cache IOA | None |
4812 |
Base PCI Integrated xSeries® Server | None |
| 4805 | PCI Cryptographic Accelerator | None |
| 4801 | PCI Cryptographic Coprocessor | None |
| 4764 | PCI-X Cryptographic Coprocessor | 4, 5 | 32 per system |
| 4746 | PCI Twinaxial Workstation Controller IOA | None |
| 2738 | 2-Port USB PCI Adapter | 4, 5 | 8 per system |
| 2749 | POWER® GXT135P Graphics Accelerator with Digital Support | None |
| 2849 | POWER GXT135P Graphics Accelerator with Digital Support | 4, 5 | 8 per system |
| 2943 | 8-Port Asynchronous Adapter EIA-232/RS-422, PCI bus | 4, 5 | 18 per system |
| 2947 | ARTIC960Hx 4-Port Multiprotocol PCI Adapter | 4, 5 | 8 per system |
| 6805 | PCI Two-Line WAN IOA | 4, 5 |
| 6808 | PCI Quad Modem IOA | 4, 5 |
| 6809 | PCI Quad Modem IOA | 4, 5 |
| 6833 | PCI 2-Line WAN with Modem | 4, 5 |
| 6834 | PCI 2-Line WAN with Modem | 4, 5 |
| 5723 | 2-Port EIA-232 Asynchronous PCI Adapter | 4, 5 | 18 per system |
* High bandwidth adapter. See the Performance notes before installing this adapter. **Extra-high bandwidth adapter. See the Performance notes before installing this adapter. 1Digital Trunk adapters have an internal cable and must be in contiguous slots. |
| 5732** | 10 Gigabit Ethernet-CX4 PCI Express™ Adapter | 1, 2, 3 | 32 |
| 5769** | 10 Gigabit Ethernet-SR PCI Express Adapter | 1, 2, 3 | 32 |
| 5772** | 10 Gigabit Ethernet-LR PCI Express Adapter | 1, 2, 3 | 32 |
| 5708** | 10 Gb FCoE PCIe Dual Port Adapter | 1, 2, 3 |
| 5735** | 8 Gigabit PCI Express Dual Port Fibre Channel Adapter | 1, 2, 3 |
| 5903** | PCIe 380MB Cache Dual - x4 3Gb SAS RAID Adapter | 1, 2, 3 | 41 |
| 5901** | PCIe Dual - x4 SAS Adapter | 1, 2, 3 | 41 |
| 5767* | 2-Port 10/100/1000 Base-TX Ethernet PCI Express Adapter | 1, 2, 3 | 41 |
| 5768* | 2-Port Gigabit Ethernet-SX PCI Express Adapter | 1, 2, 3 | 41 |
| 5717* | 4-Port 10/100/1000 Base-TX PCI Express Adapter | 1, 2, 3 | 32 |
| 5773* | 4 Gigabit PCI Express Single Port Fibre Channel Adapter | 1, 2, 3 | 41 |
| 5774** | 4 Gigabit PCI Express Dual Port Fibre Channel Adapter | 1, 2, 3 | 41 |
| 5748 | POWER GXT145 PCI Express Graphics Accelerator | 1, 2, 3 | 8 |
| 5785 | 4 Port Async EIA-232 PCIe Adapter | 1, 2, 3 | 18 |
2893 |
PCI Express 2-Line WAN with Modem | 1, 2, 3 | 41 |
2894 |
| 2728 | 4-Port USB PCIe Adapter | 1, 2, 3 | 8 |
* High bandwidth adapter. See the Performance notes before installing this adapter. **Extra-high bandwidth adapter. See the Performance notes before installing this adapter. |
Use the information in this section to help determine the maximum number of adapter that can be placed in a system while still maintaining optimum performance.
The section Maximum number of adapters supported shows maximum number adapters allowed for connectivity. However, for optimum performance, you might want to further limit the total number of high bandwidth and extra-high bandwidth adapters.
To achieve the best performance of extra-high bandwidth storage and Ethernet adapters, limit the number of expansion units to one per 12x Channel or RIO-2 adapter. Having more than one drawer on a 12x loop does not increase the I/O bandwidth but only increases the number of slots available.
For best 12x I/O performance, use the 5608 or 5609 12x Channel Adapter in slot P1-C7.
The following four tables provide guidelines on the maximum number of high bandwidth and extra-high bandwidth adapters you can use and still maintain optimum performance.
Extra-high bandwidth storage adapters
High bandwidth storage adapters
| System configuration | Adapters in system unit including both PCI-X DDR and PCIe slots | Adapters in a PCI-X I/O expansion unit connected to a GX adapter in slot P1-C8 | Adapters in a 5796 I/O expansion unit connected to a 5608 or 5609 GX adapter in slot P1-C7 | Adapters in a 5802 or 5877 I/O expansion unit connected to a 5608 or 5609 GX adapter in slot P1-C7 | System maximum |
| 2-core | 5 | 8 | 12 | ||
| 4-core | 5 | 8 | 12 | 18 | 20 for 5796 24 for 5802 or 5877 |
| 6-core | 5 | 8 | 12 | 18 | 20 for 5796 24 for 5802 or 5877 |
| 8-core | 5 | 8 | 12 | 18 | 20 for 5796 24 for 5802 or 5877 |
Extra-high bandwidth Ethernet adapters
| System configuration | Adapters in system unit including both PCI-X DDR and PCIe slots | Adapters in a PCI-X I/O expansion unit connected to a GX adapter in slot P1-C8 | System maximum |
| 2-core | 1 | 1 | 1 |
| 4-core | 2 | 2 | 2 |
| 6-core | 3 | 3 | 3 |
| 8-core | 4 | 4 | 4 |
| For optimum
performance, no more than one 10 Gb Ethernet port per two processors
should be used in a system. If one 10 Gb Ethernet port is present
per two processors, no other 10 Gb or 1 Gb ports should be used. If a 5708 adapter is used in an application with both ports active, the adapter counts as two extra-high bandwidth adapters. |
High bandwidth Ethernet adapters
| 2-core | 4 | 4 | 4 |
| 4-core | 5 | 8 | 8 |
| 6-core | 5 | 12 | 12 |
| 8-core | 5 | 16 | 16 |
| For optimum performance, no more than two 1 Gb Ethernet ports per processor should be used in a system. If two 1 Gb Ethernet ports are present per processor, no other 1 Gb or 10 Gb ports should be used. | |||
