Uninstalling a default installation
To uninstall the compiler from the default location, you can use either SMIT or installp to remove the compiler filesets.
Notes:
- If you attempt to remove a fileset that is required by another installed fileset, the selected fileset will not be removed unless its dependents are also being removed.
- The C++ runtime environment filesets such as
libc++.rte,libc++abi.rte, andlibunwind.rteand the IBM Open SDK for Rust on AIX 1.96 runtime environment fileset are not removed if you uninstall a default installation.
Using SMIT
The following steps illustrate how to uninstall rustsdk.1.96.0 using the SMIT interface:
- Run the command:
smit remove - In the
SOFTWARE namefield, enter the fileset names (wildcards accepted) separated by a space. If you have rustsdk.1.96.0 installed in its default location, enter the following name in the field:rustsdk.1.96.0*In the
REMOVE dependent software?field, select yes.Note: To preview the uninstallation, set thePREVIEW only?value to yes.
Using installp
To uninstall rustsdk.1.96.0 using the
installp command, enter the following command on the command line:
installp -ug filesetswhere filesets is the list of filesets
(wildcards accepted) to uninstall.If you have IBM Open SDK for Rust on AIX
1.96
installed in its default location, use the following
command:
installp -ug rustsdk.1.96.0\*
