Volume configuration-XMLEdit online The volume configuration-XML describes storage pool volumes. For related virsh commands, see Volume management virsh commands. <format>Specifies the image file format backing the storage pool volume.<key>Identifies the volume.<path> as child element of <volume><target>Shows the fully qualified path of the image file.<target> as child element of <volume>Specifies the image file backing a volume. <volume>Is the root element of a volume configuration-XML.Parent topic: Selected libvirt XML elements
