Downloading the CASE bundle
Create the environment variables and save the CASE bundle file.
Procedure
  1. Create these environment variables with the installer image name and version.
    For example, for version 3.5.0, specify the 2.5.0 bundle file:
    export CASE_NAME=ibm-guardium-insights
    export CASE_VERSION=2.5.0
    export LOCAL_CASE_DIR=$HOME/.ibm-pak/data/cases/$CASE_NAME/$CASE_VERSION
    export CASE_ARCHIVE=$CASE_NAME-$CASE_VERSION.tgz
    Tip: The displayed versions in the output vary based on the GuardiumĀ® Insights version that you want to install and the current version on your system.
  2. Save the CASE bundle locally:
    oc ibm-pak get $CASE_NAME \
    --version $CASE_VERSION \
    --skip-verify
    Tip: If you do not specify the CASE version, the latest CASE version downloads.
    Note: If you encounter an error similar to this example:
    No Case registries found for case ibm-cert-manager->=1.3.0 <1.3.1.tgz with the given repository URL information
    FAILED
    You might be experiencing a temporary communication problem with the remote repository. Wait a few minutes and try again.
