Interim fix 19
Refer to the known issues that are fixed in interim fix 19.
Contents of interim fix 19
- Server interim fix file
- ELM_server_patch_7.0.3.0-iFix019-ELM703M-I20250903-0215.zip
- Jazz® Reporting Service (Report Builder) interim fix file
- rs.war
- Lifecycle Query Engine interim fix file
- lqe.war
- Link Index Provider interim fix file
- ldx.war
- IBM Engineering Workflow Management client for Eclipse update site
- UpdateSiteFor_7.0.3.0-iFix019-ELM703M-I20250903-0215.zip
- Oracle Outside In Technology fix
- DN_7x_OutsideIn_8-5-7_Patch_CPU_July_2025.zip
- Known issue DT257635 fix
- ENI703-Updated_Requirement_management_CAEs.zip
- Known issue DT246685 fix
- MI147236.zip
- Known issue DT382448, DT270478, DT426551, and DT435069 fix
- RRDG_PUB_KnownIssues.zip
- IBM Engineering Workflow Management Client for Microsoft Visual Studio readme file
- readme-vsclient.txt
- IBM Engineering Workflow Management Client for Microsoft Visual Studio interim fix file
- ewm_vsclient_I7.0.3_iFix019.zip
- IBM Engineering Workflow Management Client for Microsoft Visual Studio 2022 IDE readme file
- readme-vs2022client.txt
- IBM Engineering Workflow Management Client for Microsoft Visual Studio 2022 IDE interim fix file
- ewm_vs2022client_I7.0.3_iFix019.zip
- IBM Engineering Workflow Management Client for Microsoft Windows Shell readme file
- readme_winshellclient.txt
- IBM Engineering Workflow Management for Microsoft Windows Shell interim fix file
- ewm_winshellclient_I7.0.3_iFix019.zip
Jazz Foundation
IBM Engineering Requirements Management DOORS Next
| ID | Description | Components affected |
| DT365884 | OSLC: When the server is not authenticated with a project area from a third-party tool, when in a GC, the links widget doesn't warn. | Links - OSLC |
| DT423069 | CRRRW7756W error is shown in some corner cases, preventing structural edits to the module. | Modules |
| DT448085 | Server isn't responding while working with views containing Rhapsody® Model Manager links. | Links - OSLC |
| DT114544 | Module structure is incorrect after the change set delivery if there are newer structural changes available in the source stream. | CM > Change Set |
| DT448971 | Module report generation fails when links exist to both core and binding artifacts. | Reporting - RRDG |
| DT397520 | The Paste special dialog isn't appearing while dragging and dropping artifacts between modules (with holding down the Ctrl key). | Modules |
| DT446511 | ReqIF import doesn't retain Heading property in certain scenarios. | ReqIF and DOORS Migration |
| DT095182 | Some characters for uploaded PDF documents do not display in Firefox. Note:
To apply the fix to this issue, Oracle Outside In Technology must be updated by using the DN_7x_OutsideIn_8-5-7_Patch_CPU_July_2025.zip file. |
External > OutsideIn |
| DT434361 | DOORS Next Extension API: RM.Client.getCurrentConfigurationContext isn't working. | CM > Change Set |
| DT396718 | Component template creation in GC context fails with NullPointerException. | Templates |
| DT448397 | Component or project name isn't mentioned in artifact type list while adding link constraint when there are multiple components or projects are added in GC. | Link Constraint |
| DT437414 | Cloning attempt made and failed at the delivery of the change set used to perform the clone operation. | CM > Change Set |
| DT426029 | ReqIF file missing object element data resources when exported from data generated by the DOORS migration package. | ReqIF and DOORS Migration |
| DT116548 | The XLS workbooks aren't displaying correctly after being inserted into
requirements. Note:
For more information, see Installing interim fixes for IBM Engineering Workflow Management client on Eclipse update site.
| DT444830 | Internal server error on Quick planner work board. | Tracking and Planning Commons > Quick Planner |
| DT420315 | In the EWM Eclipse client, during a reverse operation, deleted child files are not being reversed on components that don't have a root project folder. | Source Control |
| DT449321 | Running buildMapAnalysis task on large system results in integer overflow. | Enterprise Extensions |
| DT447624 | Convert IBuildableSubsetClientAPI to the latest subset artifacts. | Enterprise Extensions |
| DT210838 | Unchecking Confirm delivery to the outgoing flow target option doesn't get saved. | Visual Studio Client |
| DT419000 | Engineering Workflow Management shell component selection doesn't work while loading through the
load rules in .NET clients. |
Windows Shell |
Workaround
- Eclipse client fails to restart after applying an interim fix and shows a NullPointerException error.
First occurrence: 7.0.3
Internal ID: 576777
Problem: After upgrading with new interim fix and then restarting the Eclipse client by using Restart now option, Eclipse client doesn't restart and shows a window with NullPointerException.
Workaround: Close the window that shows the NullPointerException message, and open the IBM Engineering Workflow Management client again to get a restart. For more information, see DT393137.
Engineering Test Management
| DT443215 | Start time of a TCR is after End time for this specific scenario. | Test Execution > Test Case Results |
| DT447745 | Add debug rest call to issue modification event for an item state. | Integrations > TRS |
| DT447909 | Non-unicode character in test case name causes failure while fetching test suite execution result via OSLC. | Integrations > OSLC |
| DT448753 | Fixes to repairConfigurationsWithMergeIssues to deal with operation timeouts. | Configuration Management > Configuration Compare and Merge |
| DT448988 | Repotool repairConfigurationsWithMergeIssues command needs to exclude archived items from consideration. | Configuration Management > Configuration Compare and Merge |
| DT391272 | The size of the columns is growing each time you click OK in the Change Column Display Settings and open them again. | Test Planning > Web UI |
| DT445788 | The Limit by lifecycle status Test Items: Failed filter doesn't give accurate results. | Integrations > RRC and RDNG |
| DT447255 | The RepairConfigurationsWithMergeIssues command needs to exclude the execution results that have no steps. | Configuration Management > Configuration Compare and Merge |
| DT448402 | Issue sending email: class not found javax.mail.MessagingException. | Common Components |
| DT448984 | The repotools repairConfigurationsWithMergeIssues command fails after two hours with IOException error. | Configuration Management > Configuration Compare and Merge |
IBM Rhapsody Model Manager
| Internal | Certain squared Latin characters in architecture element properties can result in skipped resources in LQE such as the com.hp.hpl.jena.shared.CannotEncodeCharacterException: cannot encode (char) in context XML. | Reporting |
Jazz Reporting Service
| DT419539 | Unicode characters represented as hex code in Graph view. | Report Builder |
| DT442584 | Contains an aggregate expression enabled even when there are no aggregation function in the custom expression. | Report Builder |
| DT444494 | Schedule reports are failing after server rename in 7.0.3. | Report Builder |
| Internal | Access control bypass when you can run manual SQL reports. | Report Builder |
| Internal | Report count isn't filtering as per the selection criteria, and is showing all data. | Report Builder |
IBM Engineering Lifecycle Optimization - Publishing
| DT438951 | The UI shows that the reports are running even after stopping the report generation in background. | Document Builder |
