IBM® z/OS Explorer Extensions, FMID HHOPG00
  • The default SMP/E install location for MVS components did not change and remains FEL.*.
  • The default SMP/E install location for z/OS® UNIX components did not change and remains /usr/lpp/IBM/zee/*.
  • Since 16.0:
    • RSE: A customizable file has been updated:
      • zee.env: ELAXF
      • zee.env: BZUINCL
      • zee.env: . $FEL_HOME/bin/felSetToEnvvar ELAXF $ELAXF
      • zee.env: . $FEL_HOME/bin/felSetToEnvvar BZUINCL $BZUINCL
      • zee.env: FEL_HLQ
    • Since PTF UI80630:
      • CARMA: Broadcom Endevor® SCM VSAM has been updated and requires a resubmit of SFEKSAMP(CRA$VCAD) to update an existing VSAM
      • ZUnit: updates require a 15.0.5 or higher client, and Dynamic Test Runner (FMID HAL6100) APAR fix PH46624
    • Since PTF UI79588:
      • ZUnit: A customizable file has been updated:
        • AZUCSD: improved sample setup for multi-region CICS® setup
    • Since PTF UI75789:
        • zee.env: _RSE_JAVAOPTS -Dsclm.check.enable
        • zee.env: AZU_JES_PROCLIB
    • Since PTF UI74264:
        • zee.env: _RSE_JAVAOPTS -DDISABLE_DBM_INTEGRATION
      • RSE: A callable script has been provided:
        • SFEKPROC(FELIF)
