IBM
z/OS Explorer Extensions,
FMID HHOPE20
- The FMID is renamed from IBM® Developer for z Systems® to IBM
z/OS® Explorer Extensions.
- SCLM Developer Toolkit, which was deprecated in a previous release, is no
longer shipped.
- The default SMP/E install location for MVS components did
not change and remain FEL.*.
- The default SMP/E install location for z/OS UNIX components changed from /usr/lpp/IBM/idz/* to /usr/lpp/IBM/zee/*.
- Customization: The following path is no longer used:
- Customization: Customizable files have been updated:
- idz.env is moved (renamed) to zee.env
- Since PTF UI60051:
- ZUnit: A customizable member has been added:
- Since PTF UI58455:
- Proclib: A customizable member has been added:
- Proclib: Customizable members have been updated:
- PROCLIB(ELAXF*): use ELAXF
- PROCLIB(AZU*): use ELAXF
- CARMA: A customizable member has been updated:
- PARMLIB(CRACFG): add BYPASS-RESOURCE-LOCKING
- Since PTF UI56448:
- CARMA: A customizable file has been updated:
- CRASRV.properties: add system.exit
- CARMA: New function:
- Support for site-specific data in startup process
- Since PTF UI54674:
- COBOL: Customizable files have been updated:
- ELAXFCOC: add DD SYSOPTF
- ELAXFCP1: add DD SYSOPTF
