System requirements
Ensure that all system requirements are met before you use IBM Cloud Pak® for Security accelerator.
  • IBM Cloud Pak® System 2.3.3.3 Interim Fix 1.
  • (IBM® OS image for Red Hat Linux Systems) 64-Bit, 7.9 (RHEL 7.9 X64), base OS image Version 3.1.3.0:198, which is available with IBM Cloud Pak System 2.3.3.3 Interim Fix 1 default data.
  • IBM OS Image for Red Hat Enterprise Linux CoreOS 4.3.0 is available with IBM Cloud Pak System 2.3.3.3 Interim Fix 1 bundle binaries.
  • IBM Cloud Pak System Registry Service that is connected to either an external Red Hat OpenShift Container Platform docker repository or internal Docker Private Registry with available OpenShift Container Platform 4.3.1 images.
  • Red Hat Satellite Six Service that is connected to an external or internal Red Hat Satellite Server with the following packages for use with the Helper Node:
    • rhel-7-server-rpms
    • rhel-7-server-extras-rpms
  • The deployment of IBM Cloud Platform Common Services can be done on offline system.
