Powering on the library
Steps to power on the library.
About this task
  1. Plug the power cables into the power connectors on each module and into power outlets.
    Notes:
    • The library has dual redundant power supplies. To increase redundancy, plug each power cord into a different AC power circuit.
    • A power supply is required in expansion modules if drives are installed.
  2. Power on the library by pressing Power on the Base Module just below the Operator Panel and hold for 5 seconds. See Front panel for the location of the Power button. When the library is powered on, it
    1. Inventories the tape cartridges in the magazines,
    2. Checks the firmware version on all modules,
    3. Configures the tape drives.
    4. Confirms the presence of the existing modules,
    5. Searches for any new modules.
    6. When the library is powered on for the first time, the Initial Setup starts. See The Initial setup process.
