Replacement parts
TS4300 tape library has Tier 1 and Tier 2 CRUs (customer replaceable units). These CRUs are parts of the library that must be added, removed, and replaced by the customer. Tier 1 CRUs do not require tools for installation while Tier 2 CRUs need tools for installation.
There are hardware differences between some CRUs for 21U capable libraries and 48U capable libraries. All 48U CRUs will work in 21U libraries; however, 21U CRUs may not work and may cause issues if installed in a 48U library. Refer to Differences between 21U and 48U libraries to determine the library type for CRU ordering.
To order parts, contact ® Service. See Contacting IBM technical support.
Table 1. Replacement parts
Part Number Description
03WK017
5544 Base Chassis - Includes operator panel, accessor, spooling mechanism
03WK021
5544 Expansion Chassis
02XY033 3555 Base Chassis, 48U - Includes operator panel, accessor, spooling mechanism
02XV566 3555 Expansion Chassis
02XY977 Accessor, 48U - Includes Spooling Mechanism
02XY978 Spooling Mechanism, 48U
02XY976 Base Controller, 48U
00VJ962 Expansion Controller
00GH772 Expansion Cable
00GH763 LTO6 FH FC Drive Assembly
00GH761 LTO6 HH FC Drive Assembly
00GH759 LTO6 HH SAS Drive Assembly
00GH768 LTO7 FH FC Drive Assembly
00GH766 LTO7 HH FC Drive Assembly
00GH764 LTO7 HH SAS Drive Assembly
00GH814 LTO8 FH FC Drive Assembly
00GH812 LTO8 HH FC Drive Assembly
00GH810 LTO8 HH SAS Drive Assembly
02XX411 LTO9 HH SAS Drive Assembly
02XX413 LTO9 HH FC Drive Assembly
02XX415 LTO9 FH SAS Drive Assembly
02XX417 LTO9 FH FC Drive Assembly
03UW740 LTO10 FH FC Drive Assembly
00GH724 Left Magazine Asm
00GH726 Right Magazine Asm
00VJ940 Power supply
12R9314 Fibre Channel Wrap Tool
95P6566 SAS Wrap Tool
00VJ139 2 M Mini-SAS/Mini-SAS 1x Cable
15R8848 Fiber Cable HBW LC/LC 25 M
41V2120 Fiber Cable HBW LC/LC 10 M
46C2900 4 M AE1 MINI-SAS TO MINI-SAS
46C2902 3 M Y MINI-SAS HD TO MINI-SAS
46X9904 SAS 1X to 4X INTERPOSER
39M5068 Power Cable 10 AMP / 250 VAC - 2.8M
39M5081 Power Cable 10 AMP / 125 VAC - 2.8M
39M5095 Power Cable 10 AMP / 250 VAC - 2.8M
39M5102 Power Cable 10 AMP / 250 VAC - 2.8M
39M5123 Power Cable 10 AMP / 250 VAC - 2.8M
39M5130 Power Cable 10 AMP / 250 VAC - 2.8M
39M5144 Power Cable 10 AMP / 250 VAC - 2.8M
39M5151 Power Cable 10 AMP / 250 VAC - 2.8M
39M5158 Power Cable 10 AMP / 250 VAC - 2.8M
39M5165 Power Cable 10 AMP / 250 VAC - 2.8M
39M5172 Power Cable 10 AMP / 250 VAC - 2.8M
39M5199 Power Cable 10 AMP / 250 VAC - 2.8M
39M5206 Power Cable 10 AMP / 250 VAC - 2.8M
39M5219 Power Cable 10 AMP / 250 VAC - 2.8M
39M5226 Power Cable 10 AMP / 250 VAC - 2.8M
39M5240 Power Cable 10 AMP / 250 VAC - 2.8M
39M5247 Power Cable 10 AMP / 250 VAC - 2.8M
39M5254 Power Cable 10 AMP / 250 VAC - 2.8M
39M5378 Power Cable 10 AMP / 250 VAC - 4.3M
Table 2. MTM 3555 21U only replacement parts
00VJ943 3555 Base Chassis, 32 slot - Includes operator panel, accessor, spooling mechanism
02JE7201 3555 Base Chassis, 40 slot - Includes operator panel, accessor, spooling mechanism
00VJ955 3555 Accessor, 32 slot - Includes Spooling Mechanism
02JE7222 3555 Accessor, 40 slot - Includes Spooling Mechanism
00VJ956 3555 Spooling Mechanism
02XV7633 3555 Base Controller, 32 slot
1, 2 These parts can only be used in libraries having serial number 7800K0K or greater. Ensure that library firmware is at 1.2.1.0-A00 or later to support newer library serial numbers.
3 This part should only be used in libraries with 32 slot capacity. For 40 slot 21U libraries, use the '3555 Base Controller, 48U'
