Managing the Transport List
You can view and manage the Transport List from the Data Transport tab.
About this task
Consider the following points about components in the Transport List:
  • You cannot add or remove components from the Transport list if a transport job is being executed.
  • A component is removed from the Transport List if it is deleted from the source system.
Procedure
To view and manage the Transport list, follow these steps:
  1. On the source system, on the Data Transport tab, click Transport List.
  2. To view the Transport List click Manage List.
    The components that are selected for transport are listed in the Transport List.
  3. To view more information about a component, click View Properties View Properties.
  4. To remove an component from the Transport list, select the component and click Remove from List.
