Engineering Lifecycle Management pod and node affinity rules
The pods that are deployed by Engineering Lifecycle Management instance operator are preconfigured with a set of affinity rules. These pods help in achieving high availability and avoid co-location of application pods with monitoring and reporting ones.
Engineering Lifecycle Management affinity rules
Engineering Lifecycle Management pods can be classified into three categories.
  • Applications (Engineering Requirements Management DOORS® Next, Engineering Workflow Management, Engineering Test Management, Engineering Insights)
  • Common (Jazz® Team Server, Jazz Authorization Server, Global Configuration Management)
  • Reporting (LQE, Data Collection Component), Report Builder
Affinity rules set for Engineering Lifecycle Management pods ensure that the reporting pods are never co-located with common or application pods. All pods are as distributed across all available nodes as possible. If a node contains a label elm.ibm.com.type=reporting, then this node is reserved for any reporting pod (LQE or Data Collection Component).
