pserver remove command
The pserver remove command removes the perimeter server configuration associated with the operational member on a node.
Usage notes
When you run this command, the configuration of the system is recorded before and after you run the command. This information is saved in the install_dir\Members\logs directory.
Important: The configuration information includes user information, but this information is intended mainly for troubleshooting and not security auditing.
Environment
  • Windows 2008
  • Linux
Authorization
Administrative user
Syntax
execute pserver remove
Option descriptions
not sure
Examples
Example: Removing the perimeter server configuration for an operational member.
This command removes the perimeter server configuration for the operational member on the node:
