member start command
The member start command starts one or all of the members that are enabled on a node into which you are logged. Only members that are in the CONFIGURED state are started.
Usage notes
If you use the member start command to start a member on Windows, you cannot use the member start_service command to restart the member.
If your cluster has at least two catalog servers, and you stop all of your catalog servers, you must restart at least two catalog servers before the data grid is available. If you stop all of your catalog servers except one, the data grid is still available.
This command also starts the heartbeat process, which periodically checks whether members are still active. The heartbeat process starts when one or more members are started. The heartbeat process is stopped by the member stop command and the member softstop command.
Environment
- Windows 2008
- Linux
Authorization
Administrative user
Syntax
execute member start <member type>
Option descriptions
- member type
- One or all of the four member types:
- catalog
- container
- operational
- informational
- all
Examples
- Example: Starting all member types after an installation.
- This command starts all member types after an installation:
execute member start all Executing member config for grid Member configured successfully Successfully added user Server WXSCatalog started. Executing member config for grid Member configured successfully Executing member config for fabric Member configured successfully Executing member config for datasource Member configured successfully Server WXSContainer started. Executing config load for grid Config loaded successfully Executing config load for fabric Config loaded successfully Executing config load for datasource Config loaded successfully Executing config load for sys_config Config loaded successfully Executing config load for fabric_endpoint Config loaded successfully Executing member config for grid Member configured successfully Executing member config for fabric Member configured successfully Executing member config for datasource Member configured successfully Setting Passphrase that was set during install. Server Operational started. Executing member config for grid Member configured successfully Executing member config for fabric Member configured successfully Executing member config for datasource Member configured successfully Server Informational started.
