member set_logging command
The member set_logging command changes the log settings for a member from the default values.
Environment
- Windows 2008
- Linux
Authorization
Administrative user
Syntax
execute member set_logging <member type> <attribute=value>
Option descriptions
- member type
- One of the four member types:
- catalog
- container
- operational
- informational
- attribute
- One of the following four logging attributes: Restriction: You can set only one attribute at a time.
- logDirectory - The location for the log files. The server must
be restarted for the logDirectory option to take effect for the following
log files:
- start.log
- stop.log
- console.log
- messages.log
- ffdc log files
- maxFileSize - The maximum log file size in megabytes before a new log file must be created. Must be a positive integer in the range 1 - 100.
- maxFiles - The maximum number of log files that can be created. When this limit is reached, the oldest file is deleted when a new file is created. Must be a positive integer in the range 1 - 20.
- traceSpecification - A colon-separated set of trace specifications for particular packages. For example, org.apache.aries.blueprint.*=all=enabled:com.meg.b2b.*=all=enabled enables tracing on the org.apache.aries.blueprint and com.meg.b2b packages.
log files:
Examples
- Example: Limiting the size of a new log file before a new file is created.
- This command limits the size of a log file for an operational
member to 10 MB before a new file is created:
execute member set_logging operational maxFileSize=10 - Example: Setting the maximum number of log files before old log files are deleted.
- This command creates a maximum of 5 log files for an operational
member before the oldest log file is deleted when a new log file is
deleted:
execute member set_logging operational maxFiles=5
