member deactivate command
The member deactivate command deactivates a local member from a node. Removes the member configuration from the grid and disk so that the member does not restart automatically when the node is restarted. The member must be stopped before it can be deactivated.
Usage notes
This command can only be used for members on the node on which you are logged in.
When you deactivate a catalog member, you must run the member config all grid command on each node in the cluster to update the grid configuration on all members in the cluster.
Environment
  • Windows 2008
  • Linux
Authorization
Administrative user
Syntax
execute member deactivate <member type>
Option descriptions
member type
One of the four member types:
  • catalog
  • container
  • operational
  • informational
Examples
Example: Deactivating a particular member.
This command deactivates the operational member on the node that you are logged in on.
execute member deactivate operational
