maint_mode disable command
The command disables the maintenance mode for a specified domain.
Environment
  • Windows 2008
  • Linux
Authorization
Administrative user
Syntax
execute maint_mode disable <domainName>
Option descriptions
domainName
A domain that includes two or more data grids.
Examples
Example: Disabling the maintenance mode for a domain.
This command disables the maintenance mode for the DefaultDomain domain.
execute maint_mode disable DefaultDomain
