config load command
The config load command loads the common configurations into the grid to be used across members.
Usage notes
When you run this command, the configuration of the system is recorded before and after you run the command. This information is saved in the install_dir\Members\logs directory.
Important: The configuration information includes user information,
but this information is intended mainly for troubleshooting and not
security auditing.
Environment
- Windows 2008
- Linux
Authorization
Administrative user
Syntax
execute config load <datasource|fabric|fabric_endpoint|grid|sys_config|all>
Option descriptions
- datasource|fabric|fabric_endpoint|grid|sys_config
- One of the five configuration types.
Example
- Example: Loading all of the common configurations into the grid to be used across members.
execute config load all Config loaded successfully
