Configuring a virtual file system pull destination
The virtual file system pull destination is the message partition channel from which B2B Advanced Communications pulls the message response. In a RESTful HTTP or HTTPS message exchange, the messages that can be pulled by a trading partner are stored in the virtual file system pull destination. You can configure a destination to enable a trading partner to retrieve files from your system with a RESTful HTTP or HTTPS inbound one-way pull exchange. Use Destinations to create and configure a virtual file system pull destination
Before you begin
You also can import a destination as a resource from another installation of B2B Advanced Communications.
About this task
To create a virtual file system pull destination, complete the following procedure:
Procedure
What to do next
After you configure a virtual file system pull destination, you can use the destination in a RESTful HTTP or HTTPS inbound one-way pull exchange. To conduct an exchange with HTTP or HTTPS, you must configure a RESTful HTTP or HTTPS exchange profile. For more information about configuring a RESTful HTTP or HTTPS inbound one-way pull exchange, see Configuring a RESTful HTTP or HTTPS inbound pull exchange profile.
