Reusing group information
During the authentication of a user, IBM® WebSphere® Application Server stores information about which groups users belong to. This information is static for the authentication session of the user. In addition, it can be provided by an External Security Manager through a Trust Association Interceptor. In this case, IBM WebSphere Application Server does not load the information on its own. IBM WebSphere Portal Express® can participate in this flow and reuse the information from the WebSphere Application Server security context instead of retrieving it from the LDAP server. This function is also referred to as group assertion or WebSphere Application Server group assertion.
About this task
To prevent modifying existing behavior of your environment or losing existing group
information, WebSphere Portal Express does not reuse group information by
default. For this reason, you must configure WebSphere Portal Express to
reuse group information from the WebSphere Application
Server security
context. You can choose to reuse group information for user management or for access control.
- Reusing group information for user management results in all components of WebSphere Portal Express benefit from the faster group membership lookup. During the authentication session, the membership of the current user is based on the information that is provided by WebSphere Application Server. This reuse of information reduces load on your LDAP server, increases authentication performance, and results in the ability to define group membership at the authentication layer.
- Reusing group information for access control enables the system to react on possible per request changes of the WebSphere Security context. By default the Security context is not modifiable during an authentication session. However,WebSphere Application Server provides plug points, which allow the execution of a Trust Association Interceptor on every request, which might be used to establish a new security Subject on every request. In this case, Portal Access Control would be able to work with the updated subject information and would build a dynamic environment. However, this option requires more system resources, custom extensions to WebSphere Application Server security and impacts performance.
Note: The recommended option is for user management, as this case provides the performance
and functional enhancements. The second option for access control is used in specific scenarios,
typically as directed by IBM Support or IBM technical documentation.
Note: Do not combine both
options as it leads to high CPU load on your system.
Complete the following steps to reuse
group information:
