Aggregated party view example use
Aggregated party view can be used, for example, in the following way.
First, you must enable the system to persist duplicate parties in the CONFIGELEMENT table /IBM/Party/SuspectProcessing/PersistDuplicateParties/enabled. By default, the configuration is disabled.
The Aggregated party view feature can be used in the following ways:
Single party ID
You want to view a record that shows all the information that is different for the suspected duplicates of a particular party. You provide a party ID, and the transaction returns a single, aggregated party record view of all suspects in the database that are linked to the provided party, with a special suspect status of 6 -Parties are Duplicates - Collapse not permitted. This aggregated view shows the collected differences between the related suspect parties.
Multiple party IDs
You want to view a record that shows the differences between several parties. You provide a list of parties to be viewed as a single party, and the transaction returns a single, aggregated party record view that contains the resolved data of all the parties. This aggregated view shows the differences for the provided parties.
