Migrating Legacy widgets to IBM Process Mining NextGen
Widgets that are still supported in IBM Process Mining NextGen:
Preconfigured widgets
- Process model
- Filter summary
- Case variants
- Lead time distribution
- Case KPI summary
Configurable filters
- Elastic
- Matrix
- Table
Use the Elastic widget instead of the Table widget to use all IBM Process Mining NextGen's capabilities.
- Annotation
- Card
Widgets that were created in IBM Process Mining Legacy projects and migrated to IBM Process Mining NextGen are visible but not supported. They can be recreated with the Elastic widget:
Configurable legacy widgets
- Line
- Area
- Bar
- Row
- Stacked
- Bubble
Re-create the Bubble chart by using the Scatter chart type of the elastic widgets.
- Scatter
- Pie
- Custom
Widgets that were created in IBM Process Mining Legacy projects and migrated to IBM Process Mining NextGen are still supported.
Custom widgets
Legacy Custom widgets are supported in IBM Process Mining NextGen only if they do not have any legacy backend logic.
Use the Elastic widget and the custom chart type to create custom widgets in IBM Process Mining NextGen.
Using the Elastic widget as a replacement for legacy widgets
To re-create the functions of the IBM Process Mining Legacy widgets in IBM Process Mining NextGen, use the following configurations of the Elastic widget.
Activity monitor
Configuration
Dimensions DATE(End-Time)Measures # Activitiescount(*)Number Sum ServiceTimesum(servicetime)Lead time -
Style
To re-create the Resource filter functions, you can use the widget filter, or use resource as a second dimension and select stacked bar chart as chart type.
Case list
Predictive Analytics is unavailable for IBM Process Mining NextGen.
Configuration
Dimensions Case IDMeasures Is RunningIS_RUNNINGText LeadTimeleadtimeLead time Costcasecost()Amount Time % overallleadtime/overall_leadtimePercentage Cost % overallcasecost() / overall_casecostPercentage Reworkscount(activity)-count(distinct(activity))Number
To use overall_leadtime and overall_casecost, create the two following project-level custom metrics. They can also be used for any other comparison.
Case status
Configuration
Dimensions IS_RUNNINGMeasures # Casescount(distinct(caseid))Number -
Style
Influencers
You can use the Prescriptive Process Mining to understand which attributes or activities have the highest negative impact on LeadTime. For more information, see Prescriptive Process Mining
Path time histogram
Numeric distributions are unavailable in IBM Process Mining NextGen.
To use Pathtime as a dimension, create a case-level custom metric and specify the activity interval you want to consider:
Use the following Elastic widget configuration to have the same functions:
Configuration
Dimensions OPEN_RESOLUTION_PATHTIMEMeasures # Casescount(distinct(caseid))Number Filters OPEN_RESOLUTION_PATHTIME > 0 -
Style
Activity rework
Configuration
Dimensions ActivityMeasures Rework ratiocount(activity)/count(distinct(caseid))Number # Reworkscount(activity) - count(distinct(caseid))Number Rework costsum(eventcost)*(count(activity) - count(distinct(case)))Amount
Activity trend
Configuration
Dimensions DATE(End-Time)Measures # Completed Casecount(distinct(caseid))Number Filters IS_RUNNING = 0 -
Style
Automation trend
Configuration
Dimensions DATE(End-Time)"m/a"The
"m/a"value refers to the column that you inserted as an automation attribute in the Editing automation attributes section.Measures Activitiescount(*)Number Resourcescount(distinct(resource))Number
You can use either Activities or Resources as a measure according to your preferences. To see both measures at once, use the custom chart type.
You can implement more advanced configurations by using the custom chart style.
- Style
Behavior influencers
You can use the Prescriptive Process Mining to understand which attributes or activities have the highest negative impact on custom KPIs. For more information, see Prescriptive Process Mining.
Block stats
To re-create the functions of the Block stats widget, use the Card widget. Custom statistics can be created by using Custom metrics. For more information, see the Custom metrics in NextGen Engine section.
Changes and automation stats
To re-create the function of the Changes and automation stats widget, use the Card widget. Custom statistics can be created by using Custom metrics. For more information, see Custom metrics in NextGen Engine.
Path trend
Configuration
Dimensions DATE(End-Time)Measures PathTimeavg(pathtime)Lead time Occurrences (cases)count(distinct(caseid)) Number
- Style
