Developing schemas with the Rational ClearQuest Designer
You can develop or modify schemas with the Rational® ClearQuest® Designer.
As a schema developer, you can develop or modify a schema to set up new futures, such as Form Selection. For more details about these new features that can be enabled through schema updates, see the Managing and releases section.
Feedback
