Subscribing to a data product
With Data Product Hub, you can browse and subscribe to data products for your business needs. You can view your subscriptions on My subscriptions.
Placing a data product subscription
- Required roles to complete this task
- Collaborator roles: Viewer, Editor, or Admin
From the Data Product Hub home page, you can discover data products published by your community or search for specific data products. When you are ready to subscribe, you can subscribe to one data product or multiple data products at once.
Subscribe to one data product
- From the data product's detail page, click Subscribe.
- Agree to the data contract and indicate your preferred delivery method.
- Review your information, then click Subscribe.
Subscribe to multiple data products
- Add multiple data products to your cart by using one of the following methods (you can add up to 5 data products to the cart):
- From the Data Product Hub home page, click the add to cart icon on the data product tile.
- From the search page, click the add to cart icon on the data product tile.
- From the data product details page, click Add to cart.
- After you add all data products to your cart, click Go to cart from the data product details page or click My cart from the home page.
- On the cart page, you can manage your data products:
- Review the list of data products in your cart.
- Select or clear data products for subscription.
- Click View details to see more information about a specific data product.
- Click Remove to delete an individual data product from the cart.
- Click Remove all to clear all data products from the cart.
- Review the selected data products in the cart summary section. If the cart contains any retired data products, remove them before you proceed to subscribe.
- Click Proceed to subscribe after you select the required data products.
- For each data product, configure your preferred delivery methods and agree to the data contracts.
- Click Subscribe to subscribe to all products in your cart.
After your subscription request completes, you access each item using your preferred delivery method. Some data products might require you to request access and you will have to wait for approval.
Watch this video to see an overview of how Data Product Hub can enable data consumers to discover, understand, and subscribe to data products.
This video provides a visual method to learn the concepts and tasks in this documentation.
Reviewing the data product contents
You can review the product details of a data product to determine whether a data product supports your business needs.
Click the data product tile to review the following product details:
- Domain and publisher:
- The business domain that was assigned by the publisher.
- The publisher's name, the version number, version history, and the published date.
- Data product contents:
- Provides a brief description of the item and its origin.
- Recommended usage:
- Provides a description for an example application of the data product.
- Data contract:
- Provides the terms and conditions for using the data product, which can be obtained either from a URL or from an uploaded PDF file.
After reviewing the product details, complete the following steps to complete your subscription request:
- From the data product contents page, click Subscribe to open the Subscriptions details panel.
- Agree to the terms and conditions listed by the data contract.
- Choose the delivery method for each item in the data product.
- Download
- Data Extract
- Open URL
- Live access with Flight service
- Access in watsonx.data
- Deliver to watsonx.data
- Storage connection: Select the Cloud Object Storage connection that data will be stored in during the delivery process. The connection must be added to both Data Product Hub and watsonx.data instances.
- Watsonx.data connector: Select the connection to the watsonx.data instance.
- Catalog name: Enter the name of the catalog that will store the data. The name must match a catalog that you have appropriate permissions for.
- Schema name: Enter the name of the schema that will store the data.
- Table name: Enter the name of the table that will store the data.
- If the name matches an existing schema or table and you have the required permissions, data will be written to it. If it doesn’t exist and you have the appropriate permissions, it will be created automatically. Access to the newly created schema or table depends on existing policies, so you may not be able to view it.
- Access in Azure Databricks
- Enter your Azure Databricks credentials: Entra ID, Username/Password or Service Principal Credentials.
- Access in Snowflake
- Access in AWS Databricks
- Custom delivery method
- Optional: Provide a brief description of your intended use of the data product, the business needs you want to address, and the outcome you hope to achieve.
Accessing a data product
Data products are accessed differently depending upon the delivery method. You can check a data product's delivery status in your My subscriptions page. To ensure that all subscriptions reflect the latest updates, click the
Refresh status icon
The download links expire after 7 days. If your download link expires before you access your data product, you can refresh the subscription to receive a new link.
To access the data product:
Open the My Subscriptions page and locate your data product.
Access your data product according to the delivery method used:
- For Download, download your data product from a connection to your local directory.
- For Open URL, access your data product by using the provided link. For some data products, you can view the content in the subscription window. Otherwise, you can view the content in a new browser tab.
- For Data extract, download your data product as a file extract from a target connection.
- For Live access with Flight service, run the provided code snippet to retrieve your data product.
- For Deliver to watsonx.data, access your data product as a table asset in watsonx.data.
- For Access in watsonx.data, you can access your data product in watsonx.data by selecting “watsonx.data asset details."
- For Access in Azure Databricks, you can access your data product in Azure Databricks.
- For Access in AWS Databricks, you can access your data product in AWS Databricks.
- For Access in Snowflake, you can access your data product in Snowflake.
- For custom delivery methods, you can access your data product in the data source connection that the data product owner has configured for the method.
For more details about the available delivery methods, see Working with delivery methods in Data Product Hub.
Viewing and managing your subscriptions
You can view your subscriptions on My subscriptions. You can view the following details of your subscriptions:
- The subscription number
- The data product name, description, and version number
- The subscription date and subscription status
- A list of items in the data product with delivery links to access each item
- View details link to see the delivery methods used and a data preview of your data products in a table format. Data preview is only available for the following delivery methods:
If the data preview does not work, contact your Administrator.
Returning your subscription
To revoke your access to a data product:
- Click the menu icon
on the data product tile. - Select Return Subscription and review the details used in the subscription.
- Click Delete.
Reviewing data products
Consumers can view and manage their data product reviews by creating, editing or deleting their reviews. Data product owners are not permitted to manage reviews from their own data products.
Creating reviews
There are two ways to create a review for a data product.
From the My Subscriptions page:
- Scroll to the data product that you want to leave a review for.
- Select the thumbs up or thumbs down button.
- Optional: You can also add a comment to your review.
- Select Submit to post your review to the data product.
From the data product page, select the Reviews tab to post a review.
Viewing reviews
There are two ways to see data product reviews:
- Data product page: Select the Reviews tab to see how many subscribers recommended or did not recommend the product. You can also filter reviews by version.
- Homepage: View the percentage of positive reviews of a data product and click the Reviews link for more details.
Edit or delete your review
To delete or edit a review:
- Go to the data product page and select the Reviews tab.
- In your review, click the Actions menu
. The menu will only appear on the review you created. You cannot edit or delete
other reviews. - Choose Delete or Edit.
Authenticate and Use REST API to Run SQL Statements
To authenticate and use the REST API for running SQL statements, refer to the following resources for your delivery method:
- Access in watsonx.data: Presto REST API for running SQL statements in watsonx.data (SAAS & Software) steps in the Medium blog post.
- Azure Databricks: Authorize access to Azure Databricks resources in the Microsoft documentation.
