Removing referenced Java XOM resources and libraries
You want to remove a Java™ XOM resource or library at one point, but it might be referenced from rulesets or libraries. Before you remove a resource or library that is referenced, you must remove all links that point from these rulesets and libraries to the target resource or library. The library that you want to remove might be referencing resources or other libraries as well. Before you remove a library, all links that point from the library to these resources or libraries are removed as well.
About this task
Remove all links to/from the resource or library, and then remove the resource or library itself.
Note: If you do not remove the resource or library after removing these links, references might not
be updated when you redeploy the RuleApp. If it occurs, you must update them manually.
