Specifying code density in IRL
How to specify code density in IRL.
About this task
You can specify the generated bytecode density in IRL at task level or for a particular task.
Procedure
To specify code density in IRL:
  1. To specify code density at rule task level, write code as follows:
    ruletask T {
           property ilog.rules.engine.sequential.code.density = 0.5;
           algorithm = sequential;
    Another means is to set a property at the ruleset level:
    ruleset R {
    ruletask T1 {
    ruletask T2 {
    In this case, the code density of the generated bytecode is defined for both rule tasks T1 and T2.
  2. To specify code density at ruleset level, write code as follows:
    ruleset R {
           property ilog.rules.engine.sequential.code.density.
    ruletask T1 {
    ruletask T2 {
    In this case, a code density is specified for both rule tasks T1 and T2.
  3. To define the code density for a particular task by using a ruleset property, use this special generic notation:
    ruleset R {
     property ilog.rules.engine.sequential.value.code.density
    T1 = true;
    ruletask T1 {
    ruletask T2 {
    In this case, a code density is specified for rule task T1 , not for rule task T2.
