Frameworks and software specifications in Watson Machine Learning
You can use popular tools, libraries, and frameworks to train and deploy your machine learning models and functions.
Framework
A framework contains a set of reusable algorithms, tools, and libraries for developing machine learning models that you can build upon for specific application requirements. Frameworks describe the machine learning or deep learning framework that is used to build the model. You can use popular frameworks such as Tensorflow, which supports both deep learning and traditional machine learning algorithms with Watson Machine Learning for more efficient development.
Model type
Model type indicates the machine learning or deep learning framework and the framework version that is used to build the machine learning model. Machine learning or deep learning models that you build by using the same framework might not be
compatible across versions. For instance, if you built your model with pytorch-onnx_1.10 model type, you must build your model by using pytorch version 1.10 and save the model in ONNX format.
Software specification
Software specifications define the programming language and version that you use for building a model or a function. You can use software specifications to configure the software that is used for running your models and functions. You can also
define the software version to be used and include your own extensions. For example, you can use conda .yml files or custom libraries.
Platform
Platform describes the hardware platform on which you can deploy your machine learning model with a supported software specification. Depending on the framework with which you built your model, you can use Watson Machine Learning to deploy your model on Z (s390x), Power (PPC), or x86 platforms.
Lifecycle of supported frameworks and software specifications
Frameworks and software specifications that are supported when you install or upgrade to the latest version of Cloud Pak for Data go through deprecation, constriction, and discontinuation phases in future releases of Cloud Pak for Data, described as follows:
Supported: The runtime environment corresponding to the software specification is supported when you install or upgrade to the latest version of Cloud Pak for Data.
For example, the software specification
runtime-24.1-py3.11is supported in Cloud Pak for Data version 5.0. In this case, if you install or upgrade to a new Watson Machine Learning service instance, you can create or deploy machine learning models that useruntime-24.1-py3.11.For more information, see Supported deployment frameworks and software specifications.
Deprecated: The runtime environment corresponding to the software specification is supported when you install or upgrade to the latest version of Cloud Pak for Data, but will be removed in an upcoming release.
runtime-22.2-py3.10is deprectaed in Cloud Pak for Data version 4.8.4. In this case, if you install or upgrade to a new Watson Machine Learning service instance, you can create or deploy machine learning models that useruntime-22.2-py3.10. However, the support forruntime-22.2-py3.10will be discontinued in an upcoming release, so you must upgrade to the latest software specification to make sure that your deployments are supported. -
Constricted: The runtime environment corresponding to the software specification is supported when you upgrade to the latest version of Cloud Pak for Data. However, the runtime environment is not supported when you install the latest version of Cloud Pak for Data.
runtime-22.1-py3.9is constricted in Cloud Pak for Data version 4.8.0. In this case, if you install a new Watson Machine Learning service instance, you cannot create or deploy machine learning models that useruntime-22.1-py3.9. However, if you upgrade from Cloud Pak for Data version 4.7.0 to version 4.8.0, the existing models that you created and deployed with 4.7.0 are supported. You can also create new deployments based on models that use constricted software specifications during an upgrade.For more information, see Constricted software specifications.
Discontinued: The runtime environment corresponding to the software specification is not supported when you install or upgrade to the latest version of Cloud Pak for Data.
tensorflow_rt22.1-py3.9-nnpais discontinued for Cloud Pak for Data version 4.8.0. In this case, if you install or upgrade to a new Watson Machine Learning service instance, you cannot create or deploy machine learning models that usetensorflow_rt22.1-py3.9-nnpa.For more information, see Discontinued software specifications.
Managing outdated frameworks and software specifications
Update software specifications and frameworks in your models when they become outdated. Sometimes, you can seamlessly update your assets. In other cases, you must retrain or redeploy your assets.
For more information, see Managing outdated software specifications or frameworks.
