Configure IPIC connections to CICS with Docker Desktop and basic authentication
Connect to CICS® with basic authentication.
Before you begin
zosConnect-3.0 Applies to zosConnect-3.0.
Containers Applies to z/OS Connect container deployments.
Make sure that the following prerequisite tasks are complete:
  1. Prepare the sample CICS application
  2. Downloading the CICS API project sample
  3. Downloading the z/OS Connect Designer image
  4. Create the CICS tutorial workspace using Docker Desktop
About this task
In this task, you create the cics.xml file. This file uses the environmental variables defined in the docker-compose.yaml file as inputs for the IPIC connection when you start your container at run time.
With this configuration, the z/OS Connect Designer can authenticate with CICS using basic authentication. It is assumed that the target CICS region is configured to expect basic authentication credentials. That is, USERAUTH(VERIFY) is specified on the CICS IPCONN resource.
Tip: This tutorial demonstrates basic authentication. For other security configuration, see Configuring an IPIC connection to CICS.
You provide your user ID and password, then z/OS Connect Designer passes your credentials to CICS for authentication.
Figure 1. Passing only user credentials to CICS
Procedure
  1. In your text editor, create a file with the following content.
    <?xml version="1.0" encoding="UTF-8" ?>
    <server description="IPIC connection to CICS">
        <featureManager>
            <feature>zosconnect:cics-1.0</feature>
        </featureManager>
        <zosconnect_cicsIpicConnection id="cicsConn" host="${CICS_HOST}" port="${CICS_PORT}" authDataRef="cicsCredentials"/>
        <zosconnect_authData id="cicsCredentials" user="${CICS_USER}" password="${CICS_PASSWORD}"/>
    </server>
  2. Save the file as cics.xml in the directory ZCWorkspace/CatalogManagerApi/src/main/liberty/config.
  3. Verify that the new files and directories are listed correctly.
    The following screen image shows the resulting project structure:
    /ZCWorkspace
    |-- /certs
    |-- /logs
    |-- /CatalogManagerApi/src/main/liberty/config/cics.xml
    |-- docker-compose.yaml
What to do next
Start the z/OS Connect Designer and import an OpenAPI definition. See the task Starting the z/OS Connect Designer with Docker Desktop and importing an OpenAPI definition.
