Using a real-time monitoring or transaction tracking product
You can use a real-time monitoring product or create your own.
Started task Applies to z/OS Connect Servers run by using a z/OS started task procedure.
Note:
zosConnect-3.0 Applies to zosConnect-3.0.
- To see monitoring data on API provider early failures, in monitors that support early failure request monitoring, APIs must be built with the IBM z/OS Connect API provider Gradle Plugin 1.3.0, when using a z/OS Connect Server 3.0.74 or 3.0.75. Any version of the Gradle plug-in can be used for z/OS Connect Servers 3.0.76 and later.
- IBM
OMEGAMON® for JVM requires APAR OA65632 for 5.5.0 and APAR
OA65643 for 6.1.0 to monitor z/OS Connect Servers with
the
zosConnect-3.0feature.
To configure a real-time monitoring product or transaction tracking product, refer to that product's documentation and see Configuring monitoring interceptors zosConnect-2.0 or Configuring monitoring interceptors zosConnect-3.0.
To create a monitoring interceptor, refer to Creating an interceptor.
