CICS bundle project schemas
CICS® supplies schemas that describe the XML for various interfaces to CICS. Many of them describe the CICS resources and artifacts that are supported in a bundle. These schemas can help vendors to create valid resource files.
CICS XML schemas are supplied in the
/usr/lpp/cicsts/cicstsnn/schemas directory, where
cicstsnn is your CICS
release. For example, it is cicsts63 for CICS TS 6.3.
| Schema | Description | Subdirectory of schemas |
| atomservice.xsd | Schema for an ATOMSERVICE resource. | /atomservice/ |
| atomservice_app.xsd | Schema for an ATOMSERVICE resource. | /atomservice/ |
| atomservice_atom.xsd | Schema for an ATOMSERVICE resource. | /atomservice/ |
| bundle.xsd | Manifest schema for a bundle resource. See The bundle manifest schema. | /bundle/ |
| channel.xsd | Schema for a channel description document, as used by the web services assistants. See Creating a channel description document. | /channel/ |
| CICSDefinitionFile.xsd | Schema for a FILE resource. | /file/ |
| CICSDefinitionJVMServer.xsd | Schema for a JVMSERVER resource. | /jvmserver/ |
| CICSDefinitionLibrary.xsd | Schema for a LIBRARY resource. | /library/ |
| CICSDefinitionPipeline.xsd | Schema for a PIPELINE resource. | /pipeline/ |
| CICSDefinitionProgram.xsd | Schema for a PROGRAM resource. | /program/ |
| CICSDefinitionTCPIPService.xsd | Schema for a TCPIPSERVICE resource | /tcpipservice/ |
| CICSDefinitionWebservice.xsd | Schema for a WEBSERVICE resource. | /webservice/ |
| CICSDefinitionTransaction.xsd | Schema for a TRANSACTION resource. | /transaction/ |
| CICSDefinitionURIMap.xsd | Schema for a URIMAP resource. | /urimap/ |
| ciphersfile.xsd | Schema for an SSL cipher suite specification file. See Creating a TLS cipher suite specification file. | /security/ |
| EarBundle.xsd | Schema for a web application that is packaged as an EAR file. | /EAR/ |
| EbaBundle.xsd | Schema for a web application that is packaged as an EBA file. | /EBA/ |
| jvmserverTerminalHandler.xsd | No longer used. Retained for backwards compatibility. | /pipeline/ |
| jsbind.xsd | Schema for an XMLTRANSFORM resource for JavaScript Object Notation (JSON) transformation. See Mapping and transforming application data and JSON. | /xmltransform/ |
| nodejsapp.xsd | Schema for a Node.js application. | /nodejsapp/ |
| OsgiBundle.xsd | Schema for an OSGi bundle. | /OSGi/ |
| policy.xsd | Schema for policy task and system rules. | /policy/ |
| policyBaseTypes.xsd | Schema for policy rule types common to both task and system rules. | /policy/ |
| policySystemRules.xsd | Schema for system rule types. | /policy/ |
| policyTaskRules.xsd | Schema for task rule types. | /policy/ |
| provider.xsd | Schema for a provider mode pipeline configuration file. See Pipeline configuration files. | /pipeline/ |
| requester.xsd | Schema for a requester mode pipeline configuration file. See Pipeline configuration files. | /pipeline/ |
| sca-binding-cics.xsd | Schema for an SCACOMPOSITE resource. See The SCA composite schema. | /sca/ |
| sca-implmentation-cics.xsd | Schema for an SCACOMPOSITE resource. See The SCA composite schema. | /sca/ |
| soapfault.xsd | Schema for SOAP Faults generated by CICS. See The SOAP fault. | /soapfault/ |
| WARBundle.xsd | Schema for a web application that is packaged as a WAR file. | /WAR/ |
| xsdbind.xsd | Schema for an XMLTRANSFORM resource for XML transformation. See Mapping and transforming application data and XML. | /xmltransform/ |
