SET OTEL
6.3 Applies to 6.3.
Enables control over the participation of a CICS® region in an OpenTelemetry (OTel) function.
Syntax
SET OTEL
Read syntax diagramSkip visual syntax diagramSET OTELTRACE(cvda)NOOTELTRACEOTELTRACE
Conditions: INVREQ, NOTAUTH
Description
The SET OTEL command controls whether a CICS region participates in OTel. Use the command to change the CICS region OTel setting that was initiated from the OTELTRACE SIT parameter. When changing the setting from NOOTELTRACE to OTELTRACE, any accumulated task span data for completed tasks is written to SMF. Active task span data for in-flight tasks is lost.
Options
TRACE(cvda)
Enables a CICS region to participate in OpenTelemetry tracing scenarios. CVDA values are as follows:
NOOTELTRACE
This is the default value and specifies that CICS is not participating in OTel tracing scenarios. This means that CICS neither propagates received OTel trace context nor produces any span data records, regardless of transaction-level settings.
OTELTRACE
Specifies that CICS participates in OTel tracing scenarios when the OTELPROP and OTELEMIT transaction resource attributes are configured to propagate received OTel trace context and produce span data records at the transaction level.
Conditions
INVREQ
RESP2 values:
1
The value is not a valid CVDA value.
NOTAUTH
RESP2 values:
100
