SET EPADAPTER
Set the status of a specified EP adapter to enabled or disabled.
Syntax
Conditions: INVREQ, NOTAUTH, NOTFND
NOHANDLE, RESP, and
This command is threadsafe.
Description
Use the SET EPADAPTER command to change the status of a particular EP adapter. Changing the status of an EPAPAPTER has no affect on the status of any related EVENTBINDINGs.
Options
- EPADAPTER (data-value)
- Specifies the 32-character name of an EP adapter.
- ENABLESTATUS (cvda)
Specifies whether events are to be dispatched
to this EP adapter. The CVDA values are as follows:
- ENABLED
- The event processing dispatcher can dispatch events to this EP adapter. The event processing dispatcher starts dispatching events to this EP adapter immediately.
- DISABLED
- The event processing dispatcher should stop dispatching events to this EP adapter. The event processing dispatcher stops dispatching events to this EP adapter immediately. Any events already dispatched to the EP adapter are emitted.
Conditions
- INVREQ
RESP2 values are:
- 4
- ENABLESTATUS has an invalid CVDA value.
- NOTAUTH
RESP2 values are:
- 100
- 101
- The user associated with the issuing task is not authorized to update the EP adapter.
- NOTFND
RESP2 values are:
- 3
- The specified EP adapter cannot be found.
