INQUIRE PROGRAM
Retrieve information about a program, map set, or partition set.
Syntax
Conditions: APPNOTFOUND, END, ILLOGIC, NOTAUTH, PGMIDERR
NOHANDLE, RESP, and
This command is threadsafe.
Description
The INQUIRE PROGRAM command returns information about a particular program, map set, or partition set that is installed in your CICS® region. All of these resources are load modules and, therefore, CICS uses the same INQUIRE command for all three. To avoid confusion, the word module refers to the object of your inquiry, except in some cases where the option applies only to executable programs.
CICS determines the information that you request from both the resource definition and, where applicable, the load module. Information from the module takes precedence over that in the definition if there is a conflict. However, CICS inspects a module only if it is already loaded and is the copy currently available for use. CICS does not do a load for an INQUIRE PROGRAM command, and does not attempt to autoinstall a resource for which it has no definition.
If the INQUIRE PROGRAM command is issued for a program after the SET PROGRAM NEWCOPY or SET PROGRAM PHASEIN command is issued for the same program, but before a new copy of that program is loaded, certain items of information returned by the INQUIRE PROGRAM command are for an old copy, if any, of that program. This applies to the information that relates to the load module, that is, the ENTRYPOINT, LENGTH, LIBRARY, LIBRARYDSN, and LOADPOINT options. Information about the new copy of the load module is only returned after reload is complete, which is when the load module is next referenced. The next LINK, XCTL, LOAD, ENABLE, or BMS command that names the load module will cause the module to be reloaded.
Browsing
You can browse through the definitions of programs, map sets, and partition sets in your system by using the browse options START, AT, NEXT, and END, on INQUIRE PROGRAM commands. In browse mode, the definitions are returned in alphabetic order, and you can specify a starting point with the AT option if you want. See Browsing resource definitions for general information about browsing, including syntax, exception conditions, and examples.
Private resources for applications
A program that is defined as part of an application installed on a platform is private to that version of that application. For supported resource types, including programs, a resource is private if the resource is defined in a CICS bundle that is packaged and installed as part of an application, either as part of the application bundle, or as part of the application binding bundle. A program that is auto-installed by a task for an application that is deployed on a platform is also private to that version of the application. A program that is defined by any other method is publicly available for all tasks, and is known as a public program. Note that a private program that is declared as an application entry point becomes a public program when the CICS bundle containing the statement of the application entry point is made available.
You can inquire on or browse private resources using the EXEC CICS INQUIRE system programming command for the resource type. By default, CICS searches for the resources that are available to the program where the EXEC CICS INQUIRE command is issued. You can also choose to browse private resources for a specified application.
- When you issue an EXEC CICS INQUIRE PROGRAM command from a public program, information is returned about the named public PROGRAM resource. If the PROGRAM resource is not available as a public resource, a PGMIDERR condition is returned.
- When you issue an EXEC CICS INQUIRE PROGRAM command from a program that is running with an application context, information is returned about the named private PROGRAM resource for that application, if it exists. If the application does not have a private PROGRAM resource with that name, information is returned about a public PROGRAM resource with the specified name. If the resource is not available as a private PROGRAM resource for that application or as a public PROGRAM resource, a PGMIDERR condition is returned.
- When you use an EXEC CICS INQUIRE PROGRAM command in browse mode, the resources that are returned depend on the program where the command is issued, and whether you specify a particular application context. For more information about browsing private resources, including examples of browsing in a different application context, see Browsing resource definitions.
The resource signature
You can use this command to retrieve the resource signature fields. You can use these fields to manage resources by capturing details of when the resource was defined, installed, and last changed. For more information, see Identifying changes to resources (resource signatures). See Summary of the resource signature field values for detailed information about the content of the resource signature fields.
Options
- APIST(cvda) (programs only)
- Returns a CVDA value that indicates the API attribute of the installed
program definition. The API attribute is used for application programs,
PLT programs, user-replaceable modules, and task-related user exits.
The API attribute is not used for global user exits.
The API attribute on the installed PROGRAM resource for a task-related user exit program is not changed by any options specified on an ENABLE command. For a task-related user exit program, CICS always returns a CVDA using the values defined in the program resource definition.
You cannot modify an API attribute of a program using the SPI. You can change the API attribute only by redefining the API option of the program in the CICS PROGRAM resource definition, or in the program autoinstall model, and reinstalling the definition. CVDA values are as follows:
- CICSAPI
- The program is restricted to use of only the CICS permitted application programming interfaces. If the program is defined with CONCURRENCY(QUASIRENT), it always runs on the quasi-reentrant (QR) TCB. If the program is defined as CONCURRENCY(THREADSAFE) it runs on whichever TCB in use by CICS at the time that is determined as suitable. If the program is defined as CONCURRENCY(REQUIRED), it always runs on an L8 open TCB.
- OPENAPI
- The program is not restricted to only the CICS permitted application programming interfaces. CICS runs the program on its own
L8 or L9 mode open TCB, depending on the EXECKEY setting. If, when
running a CICS command, CICS requires a switch to QR TCB,
it returns to the open TCB before handing control back to the application
program.
OPENAPI requires that the program is coded to threadsafe standards and defined with CONCURRENCY(THREADSAFE) or CONCURRENCY(REQUIRED). The preferred option is to use CONCURRENCY(REQUIRED) with OPENAPI, although CONCURRENCY(THREADSAFE) is allowed for compatibility with previous releases.
- APPLICATION(data-area)
- Specifies or returns the application name element of the application context. The application name can be up to 64 characters in length.
- APPLMAJORVER(data-area)
- Specifies or returns the application major version element of the application context, in fullword binary form. For an inquiry on a public PROGRAM resource, if the program is not defined as an application entry point, APPLMAJORVER returns a value of -1.
- APPLMINORVER(data-area)
- Specifies or returns the application minor version element of the application context, in fullword binary form. For an inquiry on a public PROGRAM resource, if the program is not defined as an application entry point, APPLMINORVER returns a value of -1.
- APPLMICROVER(data-area)
- Specifies or returns the application micro version element of the application context, in fullword binary form. For an inquiry on a public PROGRAM resource, if the program is not defined as an application entry point, APPLMICROVER returns a value of -1.
- CEDFSTATUS(cvda) (programs only)
- Returns a CVDA value that indicates the action taken by the execution
diagnostic facility (EDF) transaction if this module is run under
EDF. CVDA values are as follows:
- CEDF
- EDF diagnostic screens are displayed. If the program was translated with the EDF option, all EDF screens are displayed. If the program was translated with NOEDF, only the program initiation and termination screens appear.
- NOCEDF
- No EDF screens are displayed.
- NOTAPPLIC
- EDF does not apply because the module is a remote program, a map set, or a partition set.
- CHANGEAGENT(cvda)
- Returns a CVDA value that identifies the agent that made the last
change to the resource definition. The possible values are as follows:
- AUTOINSTALL
- The resource was autoinstalled.
- CREATESPI
- The resource definition was last changed by an EXEC CICS CREATE command.
- CSDAPI
- The resource definition was last changed by a CEDA transaction or the programmable interface to DFHEDAP.
- CSDBATCH
- The resource definition was last changed by a DFHCSDUP job.
- DREPAPI
- The resource definition was last changed by a CICSPlex® SM BAS API command.
- DYNAMIC
- The resource definition was last changed by a Link to Liberty application.
- OVERRIDE
- The resource definition was last changed by application of an override rule in the resource overrides file.
- SYSTEM
- The resource definition was last changed by the CICS or CICSPlex system.
- CHANGEAGREL(data-area)
- Returns a 4-digit number of the CICS release that was running when the resource definition was last changed: for example, 0760 is the identifier for CICS TS for z/OS®, Version 6.3.
- CHANGETIME(data-area)
- Returns an ABSTIME value that represents the time stamp when the resource definition was last changed. For more information about the format of the ABSTIME value, see FORMATTIME.
- CHANGEUSRID(data-area)
- Returns the 8-character user ID that ran the change agent.
- COBOLTYPE(cvda) (programs only)
- Returns a CVDA value that indicates the type of COBOL in which
the module is written, if it is a COBOL program. The type is determined
by inspecting the load module. CVDA values are as follows:
- COBOL
- The module is an OS/VS COBOL program. (OS/VS COBOL programs cannot run under this CICS Transaction Server version.)
- COBOLII
- The module is a COBOL program that has been compiled with VS COBOL II or a more recent COBOL compiler.
- NOTAPPLIC
- The module has been loaded and it is not a COBOL program, or the module has not been loaded and it is not defined as a COBOL program.
- NOTINIT
- The module is defined as a COBOL program, but the type cannot be determined because the module has not been loaded yet.
- CONCURRENCY
- Returns a CVDA value that indicates the concurrency attribute
of the installed program definition. The CVDA values are as follows:
- QUASIRENT
- The program is defined as being quasi-reentrant, and can run only under the CICS QR TCB.
- THREADSAFE
- The program is defined as threadsafe, and can run under whichever TCB is in use by its user task when the program is given control. This can be either an open TCB or the CICS QR TCB.
- REQUIRED
- The program is defined as threadsafe, and must run on an open TCB. The type of open TCB used depends on the API setting.
Notes:- If the program is not yet loaded, or is waiting to be reloaded following a NEWCOPY or PHASEIN request, the concurrency attribute is derived from the installed program resource definition. Note that the default for the program definition is QUASIRENT. However, in the case of a Language Environment®-conforming program, the concurrency as originally defined can be overridden when the program is later loaded. If CICS finds that the program itself contains a CONCURRENCY value defined by Language Environment runtime options, the installed program resource definition is updated by the Language Environment runtime option.
- The CONCURRENCY attribute on the installed program resource definition is not changed by the FORCEQR system initialization parameter. CICS returns a CVDA of THREADSAFE for a threadsafe-defined program, even if FORCEQR=YES is specified.
You cannot modify the concurrency attribute of a program using the SPI; the CONCURRENCY option is not supported on the EXEC CICS SET PROGRAM command. You can change the concurrency only by redefining the CONCURRENCY option of the program in the CICS program resource definition, or in the program autoinstall model, and then reinstalling the definition.
- COPY(cvda)
- Returns a CVDA value that indicates whether a new copy of the
module is required to make it available for use. This requirement
occurs after CICS attempts
to load the module and cannot find it, because CICS marks it
not loadable
to avoid the overhead of further load attempts. To make the module available again, issue a SET PROGRAM COPY command or its CEMT equivalent. Ensure that the program exists in one of the libraries in the DFHRPL or dynamic LIBRARY concatenation before doing so. CVDA values are as follows:- NOTREQUIRED
- A new copy is not required. This CVDA value is always returned for Java™ programs that run in a JVM.
- REQUIRED
- A new copy is required.
- DATALOCATION(cvda) (programs only)
- Returns a CVDA value that indicates whether this module can accept
data addresses higher than 16 MB. CVDA values are as follows:
- ANY
- The program can accept an address above 16 MB.
- BELOW
- The program requires any data address returned to it from CICS to be less than 16 MB.
- NOTAPPLIC
- The option does not apply because the module is a remote program, a map set, or a partition set.
- DEFINESOURCE(data-area)
- Returns the 8-character source of the resource definition. The DEFINESOURCE value depends on the CHANGEAGENT value. For more information, see Summary of the resource signature field values.
- DEFINETIME(data-area)
- Returns an ABSTIME value that represents the time stamp when the resource definition was created.
- DYNAMSTATUS(cvda) (programs only)
- Returns a CVDA value that indicates whether, if the program is the subject of a program-link
request, the request can be dynamically routed. CVDA values are as follows:
- DYNAMIC
- If the program is the subject of a program-link request, the CICS dynamic routing program is invoked. Providing that a remote server region is not named explicitly on the SYSID option of the LINK command, the routing program can route the request to the region on which the program is to run.
- NOTDYNAMIC
- If the program is the subject of a program-link request, the dynamic routing program is not
invoked.
For a distributed program link (DPL) request, the server region on which the program is to run must be specified explicitly on the REMOTESYSTEM option of the PROGRAM definition or on the SYSID option of the LINK command; otherwise, it defaults to the local region.
For information about the dynamic routing of DPL requests, see Dynamically routing DPL requests.
- ENTRYPOINT(ptr-ref)
- Returns the entry point of the module, if it is loaded. CICS program load services set
the entry point according to the addressing mode of the load module:
- AMODE(24): bit 0 is 0 and bit 31 is 0.
- AMODE(31): bit 0 is 1 and bit 31 is 0.
- AMODE(64): bit 0 is 0 and bit 31 is 1.
If the module is not loaded, or is a remote program, or is a Java program that runs in a JVM, a null pointer (X'FF000000') is returned.
- EXECKEY(cvda) (programs only)
- Returns a CVDA value that indicates the storage key of the module, if it is an executable
program. The storage key can limit the areas of storage that the program can access, depending on
other variables. See the ISOLATEST option of the INQUIRE TASK and INQUIRE TRANSACTION commands, the
STOREPROTECT and TRANISOLATE options of the INQUIRE SYSTEM command, and the general discussion of
storage protection in How you can protect CICS storage. CVDA values are as follows:
- CICSEXECKEY
- The program runs in CICS key.
- NOTAPPLIC
- The module is a remote program, a map set, or a partition set.
- USEREXECKEY
- The program runs in user key.
- EXECUTIONSET(cvda) (programs only)
- Returns a CVDA value that indicates whether the module is restricted
to the distributed program link subset of the CICS API. The EXECUTIONSET option applies only
to executable programs, and governs the API only when a program is
called locally. When it is called remotely, that is, executing at
or below the level of a program invoked by a distributed program link,
a program is always restricted to this subset. CVDA values are as
follows:
- DPLSUBSET
- The program is always restricted.
- FULLAPI
- The program is not restricted unless called remotely.
- NOTAPPLIC
- EXECUTIONSET does not apply because the module is a remote program, a map set, or a partition set.
- HOLDSTATUS(cvda)
- Returns a CVDA value that indicates whether a copy of the module
is currently loaded with the HOLD option. CVDA values are as follows:
- HOLD
- A copy is currently loaded with the HOLD option.
- NOHOLD
- No copy is currently loaded with the HOLD option.
- NOTAPPLIC
- The module is not currently loaded, or is a remote program.
- INSTALLAGENT(cvda)
- Returns a CVDA value that identifies the agent that installed
the resource. The possible values are as follows:
- AUTOINSTALL
- BUNDLE
- The resource was installed by a bundle deployment.
- CREATESPI
- The resource was installed by an EXEC CICS CREATE command.
- CSDAPI
- The resource was installed by a CEDA transaction or the programmable interface to DFHEDAP.
- DYNAMIC
- The resource definition was last installed by a Link to Liberty application.
- GRPLIST
- The resource was installed by GRPLIST INSTALL.
- SYSTEM
- The resource was installed by the CICS or CICSPlex SM system.
- INSTALLTIME(data-area)
- Returns an ABSTIME value that represents the time stamp when the resource was installed.
- INSTALLUSRID(data-area)
- Returns the 8-character user ID that installed the resource.
- JVMCLASS(data-area) (Java programs only)
- Returns the name, in 255 characters, of the main class in the Java program to be given control by the JVM, as specified in the program definition.
- JVMPROFILE(data-area) (Java programs only)
- Returns the name of the JVM profile that is to be used for the pooled JVM in which this Java program runs. The name can be up to 8 characters in length.
- JVMSERVER(data-area) (Java programs only)
- Returns the name of the JVM server in which this Java program runs. The name can be up to 8 characters in length.
- LANGDEDUCED(cvda) (programs only)
- Returns a CVDA value that indicates the language for the loaded
module. If the module is not yet loaded, CICS cannot deduce the language. In this case,
the CVDA value indicates the defined language taken from the resource
- ASSEMBLER
- The language is assembler.
- C
- The language is C® or C++.
- COBOL
- The language is COBOL.
- JAVA
- The language is Java.
- LE370
- The module, whatever its language, was compiled to run with Language Environment.
- NOTAPPLIC
- LANGUAGE does not apply because the module is a remote program, a map set, or a partition set.
- NOTDEFINED
- The language was not specified in the resource definition, and has not been loaded.
- PLI or PL1
- The language is PL/I.
- LANGUAGE(cvda) (programs only)
- Returns a CVDA value that indicates the program language. The CICS program manager deduces the
correct language, except for programs written in assembler without
the DFHEAI or DFHEAG stub. In this case, the LANGUAGE attribute of
the program definition is used to return a value. CVDA values are
as follows:
- ASSEMBLER
- C
- The language is C.
- COBOL
- LE370
- The module, whatever its language, exploits multi-language support, or was compiled with a Language Environment-conforming compiler.
- NOTAPPLIC
- NOTDEFINED
- The language was not specified in the resource definition.
- PLI or PL1
- LENGTH(data-area)
- Returns a fullword binary field that gives the length of the module in bytes. A value of 0 is returned if the module has not been loaded in the current CICS session. A value of -1 is returned if it is a remote program or a Java program that runs in a JVM.
- LIBRARY(data-area)
- Returns the 8-character name of the library resource from which
this program was loaded. This data area is blank if the program has
not been loaded, or if the LPASTATUS is LPA, indicating that the program
has been loaded from the LPA. Note:
- If the program was loaded from an installed library, the LIBRARY and LIBRARYDSN names are returned.
- If the program was loaded from a library that has been disabled, the LIBRARY name is returned but the LIBRARYDSN is blank.
- If the program was loaded from a library that has been discarded, both LIBRARY and LIBRARYDSN names are blank.
- LIBRARYDSN(data-area)
- Returns the 44-character name of the data set from which the program
was loaded. This data area is blank if the program has not been loaded,
or if the LPASTATUS is LPA, indicating that the program has been loaded
from the LPA.
- LOADPOINT(ptr-ref)
- Returns the load address of the module. If it is not currently loaded, or if the program is a Java program running in a JVM, a null pointer (X'FF000000') is returned.
- LPASTATUS(cvda)
- Returns a CVDA value that indicates whether the module resided
in the link pack area when it was last used. CVDA values are as follows:
- LPA
- The copy used was in the link pack area (LPA) or the extended link pack area (ELPA).
- NOTAPPLIC
- The module has not been used, is a remote program, or is a Java program.
- NOTLPA
- The copy used was in CICS dynamic storage.
- OPERATION(data-value)
- Returns, in a 64-character area, the name of the application operation for which this program is defined as an entry point. If the program is not defined as an application entry point, OPERATION returns 64 blanks.
- PLATFORM(data-area)
- Specifies or returns the platform name element of the application context. The platform name can be up to 64 characters in length. For an inquiry on a public PROGRAM resource, if the resource is not defined as an application entry point, PLATFORM returns 64 blanks.
- PROGRAM(data-value)
- Specifies the name of the program, map set, or partition set about which you are inquiring. The name can be up to 8 characters in length.
- PROGTYPE(cvda)
- Returns a CVDA value that indicates the type of module. CVDA values
are as follows:
- MAPSET
- The module is a map set. (MAP is still a synonym for MAPSET, but MAPSET is the preferred CVDA value.)
- PARTITIONSET
- The module is a partition set.
- PROGRAM
- The module is an executable program.
- REMOTENAME(data-area) (programs only)
- Returns the 8-character name by which the module is known in the CICS region named in the REMOTESYSTEM option of its PROGRAM definition. The REMOTENAME option applies only to programs, and only to those defined to be remote; for local programs, map sets, and partition sets, the value returned is blanks.
- REMOTESYSTEM(data-area) (programs only)
- Returns the 4-character name of the CICS region in which the module is defined (from the REMOTESYSTEM value in the PROGRAM definition). It applies only to programs, and only to those defined to be remote; for local programs, map sets, and partition sets, the value returned is blanks.
- REPLICATION(cvda)
- Returns a CVDA value that indicates whether the program is a replicator. The CVDA values are as follows:
- REPLICATOR
- The program is a replicator program and has full access to VSAM data sets that have an AVAILABILITY state of RREPL.
- NOREPLICATOR
- The program is not a replicator program and has only read access to VSAM data sets that have an AVAILABILITY state of RREPL.
- RESCOUNT(data-area)
- Returns a fullword binary field that gives the number of separate uses of this module that are taking place at the time of this inquiry. A value of -1 is returned if the module is either a remote program, or a Java program that runs in a JVM.
- RESIDENCY(cvda) (programs only)
- Returns a CVDA value that indicates the program's residency attributes.
- RESIDENT
- The program is permanently resident. It is defined as RESIDENT(YES).
- NONRESIDENT
- The program has been defined as RESIDENT(NO).
- RUNTIME(cvda)
- Returns a CVDA value that indicates the runtime environment of
the program. CVDA values are as follows:
- JVM
- The program is a Java program that runs in a Java Virtual Machine (JVM).
- LE370
- The program will run with Language Environment runtime support.
- NONLE370
- The program will run with a language-specific runtime environment.
- NOTAPPLIC
- RUNTIME does not apply because the module is a map set or a partition set.
- UNKNOWN
- The program runtime environment is unknown, because the program has not been loaded by CICS, and therefore its source language has not been deduced, which dictates the runtime environment to be used.
- XPLINK
- The program is a C or C++ program that has been compiled using the XPLINK option.
- SHARESTATUS(cvda)
- Returns a CVDA value that indicates where CICS obtains the module the next time a new
copy is required. CVDA values are as follows:
- NOTAPPLIC
- SHARESTATUS does not apply because the module is a remote program or a Java program that runs in a JVM.
- PRIVATE
- The module is loaded from one of the libraries in the DFHRPL or dynamic LIBRARY concatenation.
- SHARED
- The LPA copy is to be used, if one is available. If it is not, the module is loaded as if SHARESTATUS were PRIVATE.
- STATUS(cvda)
- Returns a CVDA value that indicates whether the module is available
for use. CVDA values are as follows:
- DISABLED
- The module is not available for use.
- ENABLED
- The module is available for use.
- TRANSID(data-area) (programs only)
- Returns the 4-character name of the transaction under which this module, which must be a program, runs remotely; that is, the transaction identifier that the remote region assigns to the task created there to execute it when a task in the local region links to it. This value comes from the TRANSID option value in the PROGRAM definition and applies only to programs defined as remote. For local programs, map sets, and partition sets, and when no TRANSID is specified for a remote program, the value returned is blanks.
- USECOUNT(data-area)
- Returns a fullword binary field that gives the total number of times the module has been used
since the start of the current CICS session. The use count is
provided for all modules including Java programs, except for
remote programs. A value of -1 is returned if the program is remote.
The maximum value is 2147483647. The use count is not changed after this value is reached.
Conditions
- APPNOTFOUND
- RESP2 values:
- 1
- A START command has been issued specifying an application context. The named application is not found.
- END
- RESP2 values:
- 2
- There are no more resource definitions of this type.
- ILLOGIC
- RESP2 values:
- 1
- You have issued a START command when a browse of this resource type is already in progress, or you have issued a NEXT or an END command when a browse of this resource type is not in progress.
- NOTAUTH
- RESP2 values:
- 100
- 101
- The user associated with the issuing task is not authorized to access this particular resource in the way required by this command.
- PGMIDERR
- RESP2 values:
- 1
- The program cannot be found. If this error occurs on an INQUIRE PROGRAM NEXT command, an earlier cataloging error has made a PROGRAM, MAPSET, or PARTITIONSET definition unusable, and the definition must be discarded and reinstalled.
