INQUIRE OTEL
6.3 Applies to 6.3.
Retrieve information about CICS® participation in OpenTelemetry scenarios at region level.
Syntax
INQUIRE OTEL
Read syntax diagramSkip visual syntax diagramINQUIRE OTELTRACE(cvda)
Conditions: INVREQ, NOTAUTH
Description
The INQUIRE OTEL command returns information about the whether a CICS region is set to participate in an OpenTelemetry (OTel) function.
Options
TRACE(cvda)
Returns a CVDA value indicating whether a CICS region is set to participate in OTel tracing scenarios. CVDA values are as follows:
NOOTELTRACE
This is the default value and specifies that CICS is not participating in OTel tracing scenarios. This means that CICS neither propagates received OTel trace context nor produces any span data records, regardless of transaction-level settings.
OTELTRACE
Specifies that CICS participates in OTel tracing scenarios when the OTELPROP and OTELEMIT transaction resource attributes are configured to propagate received OTel trace context and produce span data records at the transaction level.
Conditions
INVREQ
RESP2 values:
1
The value is not a valid CVDA value.
NOTAUTH
RESP2 values:
100
