INQUIRE JVMSERVER
Retrieve information about the JVM server runtime environment in the CICS® region.
Syntax
INQUIRE JVMSERVER
Read syntax diagramSkip visual syntax diagramINQUIRE JVMSERVER( data-value)CHANGEAGENT( cvda)CHANGEAGREL( data-area)CHANGETIME( data-area)CHANGEUSRID( data-area)CURRENTHEAP( data-area)DEFINESOURCE( data-area)DEFINETIME( data-area)ENABLESTATUS( cvda)GCPOLICY( data-area)INITHEAP( data-area)INSTALLAGENT( cvda)INSTALLTIME( data-area)INSTALLUSRID( data-area)JAVAHOME( data-area)JVMPROFILE( data-area)LERUNOPTS( data-area)LOG( data-area)MAXHEAP( data-area)OCCUPANCY( data-area)PID( data-area)PROFILE( data-area)PROFILEDIR( data-area)STDERR( data-area)STDOUT( data-area)THREADCOUNT( data-area)THREADLIMIT( data-area)TRACE( data-area)WORKDIR( data-area)
Conditions: END, ILLOGIC, NOTAUTH, NOTFND
This command is threadsafe.
Description
The INQUIRE JVMSERVER command retrieves information about one or more JVM servers that are running in the CICS region.
Browsing
You can browse through all the JVMSERVER resources that are installed in the region, using the browse options (START, NEXT, and END) on INQUIRE JVMSERVER commands. See Browsing resource definitions for general information about browsing, including syntax, exception conditions, and examples.
The resource signature
You can use this command to retrieve the resource signature fields. You can use these fields to manage resources by capturing details of when the resource was defined, installed, and last changed. For more information, see Identifying changes to resources (resource signatures). See Summary of the resource signature field values for detailed information about the content of the resource signature fields.
Options
CHANGEAGENT(cvda)
Returns a CVDA value that identifies the agent that made the last change to the resource definition. The possible values are as follows:
CREATESPI
The resource definition was last changed by an EXEC CICS CREATE command.
CSDAPI
The resource definition was last changed by a CEDA transaction or the programmable interface to DFHEDAP.
CSDBATCH
The resource definition was last changed by a DFHCSDUP job.
DREPAPI
The resource definition was last changed by a CICSPlex® SM BAS API command.
OVERRIDE
The resource definition was last changed by application of an override rule in the resource overrides file.
CHANGEAGREL(data-area)
Returns a 4-digit number of the CICS release that was running when the resource definition was last changed: for example, 0760 is the identifier for CICS TS for z/OS®, Version 6.3.
CHANGETIME(data-area)
Returns an ABSTIME value that represents the time stamp when the resource definition was last changed. For more information about the format of the ABSTIME value, see FORMATTIME.
CHANGEUSRID(data-area)
Returns the 8-character user ID that ran the change agent.
CURRENTHEAP(data-area)
Returns a doubleword binary value indicating the current size of the heap in bytes that is allocated to the JVM server.
DEFINESOURCE(data-area)
Returns the 8-character source of the resource definition. The DEFINESOURCE value depends on the CHANGEAGENT value. For more information, see Summary of the resource signature field values.
DEFINETIME(data-area)
Returns an ABSTIME value that represents the time stamp when the resource definition was created.
ENABLESTATUS(cvda)
Returns a CVDA value indicating the overall status of the JVM server. The CVDA values are as follows:
ENABLED
The JVM server has started and is enabled for use.
ENABLING
The JVM server is starting.
DISABLED
The JVM server is stopped and any new requests cannot be processed.
DISABLING
The JVM server is stopping. Threads can still be running if they were started before the JVM server was stopped.
DISCARDING
The JVMSERVER resource is being discarded.
GCPOLICY(data-area)
Returns a 32-character value indicating the garbage collection policy that is being used by the JVM server.
INITHEAP(data-area)
Returns a doubleword binary value that indicates the initial size of the heap in bytes that is allocated to the JVM server. This value is set by the -Xms option in the JVM profile.
INSTALLAGENT(cvda)
Returns a CVDA value that identifies the agent that installed the resource. The possible values are as follows:
BUNDLE
The resource was installed by a bundle deployment.
CREATESPI
The resource was installed by an EXEC CICS CREATE command.
CSDAPI
The resource was installed by a CEDA transaction or the programmable interface to DFHEDAP.
GRPLIST
The resource was installed by GRPLIST INSTALL.
INSTALLTIME(data-area)
Returns an ABSTIME value that represents the time stamp when the resource was installed.
INSTALLUSRID(data-area)
Returns the 8-character user ID that installed the resource.
JAVAHOME(data-area)
Returns the first 255 characters of the full path to the home directory of the version of Java used for the JVM server. This option can be configured using the JVM server profile options.
JVMPROFILE(data-area)
Returns the 1-8 character profile name of the JVM server.
JVMSERVER(data-value)
Specifies the name of the JVMSERVER resource about which you are inquiring. The name can be up to 8 characters in length.
LERUNOPTS(data-area)
Returns the 1-8 character name of the program that defines the runtime options for the Language Environment enclave.
LOG(data-area)
Returns the first 255 chracters of the full path to the log output file for the JVM server. This destination can be configured using the JVM server profile options.
MAXHEAP(data-area)
Returns a doubleword binary value that indicates the maximum size of the heap in bytes that is allocated to the JVM server. This value is set by the -Xmx option in the JVM profile.
OCCUPANCY(data-area)
Returns a doubleword binary value that indicates the size of the heap in bytes after the last garbage collection ran in the JVM server.
PID(data-area)
Returns a fullword value that indicates the process ID (PID) of the JVM.
PROFILE(data-area)
Returns the first 255 characters of the full path to the JVM profile.
PROFILEDIR(data-area)
Returns a 240-character data value of the directory on z/OS UNIX that contains the JVM profile for the JVM server. For a JVM server that is defined in a local CICS region, which uses a JVM profile stored in the local CICS region, the value is the directory specified by the JVMPROFILEDIR system initialization parameter system initialization parameter for the CICS region. For a JVM server that is defined in a CICS bundle, which uses a JVM profile packaged in the CICS bundle, the value is the CICS bundle subdirectory where the JVM profile is stored.
STDERR(data-area)
Returns the first 255 characters of the full path to the stderr output file for the JVM server. This destination can be configured using the JVM server profile options.
STDOUT(data-area)
Returns the first 255 characters of the full path to the stdout output file for the JVM server. This destination can be configured using the JVM server profile options.
THREADCOUNT(data-area)
Returns a fullword binary value giving the number of threads that are currently running inside the JVM server. The value returned by a Liberty JVM server will reflect that threads are managed within a thread pool of Liberty. This means that there will be a positive value even when no workload is running. This value may increase or decrease spontaneously due to an internal algorithm.
THREADLIMIT(data-area)
Returns a fullword binary value giving the number of threads that are allowed in the Language Environment enclave for the JVM server. Each thread runs under a T8 TCB.
TRACE(data-area)
Returns the first 255 characters of the full path to the trace output file for the JVM server. This destination can be configured using the JVM server profile options.
WORKDIR(data-area)
Returns the first 255 characters of the full path to the working directory associated with the JVM server. This option can be configured using the JVM server profile options.
Conditions
END
RESP2 values:
2
There are no more resource definitions of this type.
ILLOGIC
RESP2 values:
1
You have issued a START command when a browse of this resource type is already in progress, or you have issued a NEXT or an END command when a browse of this resource type is not in progress.
NOTAUTH
RESP2 values:
100
101
The user associated with the issuing task is not authorized to access this jvmserver.
NOTFND
RESP2 values:
3
The JVMSERVER resource cannot be found.
