INQUIRE JOURNALMODEL
Retrieve information about installed journal models, thus enabling you to obtain corresponding log stream names.
Syntax
Conditions: END, ILLOGIC, NOTAUTH, NOTFND
NOHANDLE, RESP, and
This command is threadsafe.
Description
The INQUIRE JOURNALMODEL command returns information about a particular installed journal model so that you can obtain corresponding log stream names.
Browsing
You can also browse through all of the journal model names on your system by using the browse options, START, NEXT, and END, on INQUIRE JOURNALMODEL commands. See Browsing resource definitions for general information about browsing, including syntax, exception conditions, and examples.
CICS® returns journal models in alphanumeric sequence of the JOURNALNAMEs specified in the journal model, but with specific names being returned before the generic names. The following examples of journal names defined on journal models show the order in which the journal models are returned on a browse JOURNALMODEL operation:
DFHJ25
DFHJ%0
DFH*
USERJNL1
USERJNL2
USERJNL*
The resource signature
You can use this command to retrieve the resource signature fields. You can use these fields to manage resources by capturing details of when the resource was defined, installed, and last changed. For more information, see Identifying changes to resources (resource signatures). See Summary of the resource signature field values for detailed information about the content of the resource signature fields.
Options
- CHANGEAGENT(cvda)
- Returns a CVDA value that identifies the agent that made the last
change to the resource definition. The possible values are as follows:
- CREATESPI
- The resource definition was last changed by an EXEC CICS CREATE command.
- CSDAPI
- The resource definition was last changed by a CEDA transaction or the programmable interface to DFHEDAP.
- CSDBATCH
- The resource definition was last changed by a DFHCSDUP job.
- DREPAPI
- The resource definition was last changed by a CICSPlex® SM BAS API command.
- OVERRIDE
- The resource definition was last changed by application of an override rule in the resource overrides file.
- CHANGEAGREL(data-area)
- Returns a 4-digit number of the CICS release that was running when the resource definition was last changed: for example, 0760 is the identifier for CICS TS for z/OS®, beta.
- CHANGETIME(data-area)
- Returns an ABSTIME value that represents the time stamp when the resource definition was last changed. For more information about the format of the ABSTIME value, see FORMATTIME.
- CHANGEUSRID(data-area)
- Returns the 8-character user ID that ran the change agent.
- DEFINESOURCE(data-area)
- Returns the 8-character source of the resource definition. The DEFINESOURCE value depends on the CHANGEAGENT value. For more information, see Summary of the resource signature field values.
- DEFINETIME(data-area)
- Returns an ABSTIME value that represents the time stamp when the resource definition was created.
- INSTALLAGENT(cvda)
- Returns a CVDA value that identifies the agent that installed
the resource. The possible values are as follows:
- CREATESPI
- The resource was installed by an EXEC CICS CREATE command.
- CSDAPI
- The resource was installed by a CEDA transaction or the programmable interface to DFHEDAP.
- GRPLIST
- The resource was installed by GRPLIST INSTALL.
- INSTALLTIME(data-area)
- Returns an ABSTIME value that represents the time stamp when the resource was installed.
- INSTALLUSRID(data-area)
- Returns the 8-character user ID that installed the resource.
- JOURNALMODEL(data-value)
- Specifies the 1- to 8-character name of an installed journal model.
- JOURNALNAME(data-area)
- Returns the 1- to 8-character journal name, which can be a specific or a generic name. See JOURNALMODEL resources for further information about the JOURNALNAME operand.
- STREAMNAME(data-area)
- Returns the MVS log stream
name (LSN) associated with the JOURNALMODEL entry.
The name can be a specific LSN or a template using a maximum of any three of the four symbols &USERID, &APPLID, &JNAME, and &SYSID.
The name, LSN or template, can be up to 26 characters in length. Names shorter than 26 characters are padded with trailing blanks (X'40').
- TYPE(cvda)
- Indicates the log stream type. The CVDA values are as follows:
- DUMMY
- Records are not written to any log stream.
- MVS
- Records are written to an MVS log stream.
- SMF
- Records are written to the MVS SMF log stream.
Conditions
- END
- RESP2 values:
- 2
- All authorized resources have been retrieved. All data areas specified on this command are left unchanged.
- ILLOGIC
- RESP2 values:
- 1
- A START has been given when a browse is already in progress, or a NEXT or END has been given without a preceding START.
- 2
- The browse token is not valid.
- NOTAUTH
- RESP2 values:
- 100
- The user is not authorized for this command.
- NOTFND
- RESP2 values:
- 1
- The specified journal model was not found.
