INQUIRE EPADAPTER
Retrieve information about a specified event processing adapter.
Syntax
INQUIRE EPADAPTER
Read syntax diagramSkip visual syntax diagramINQUIRE EPADAPTER( data-value)ADAPTERTYPE( cvda)AUTHORITY( cvda)AUTHUSERID( data-area)CONFIGDATA1( data-area)DATAFORMAT( cvda)EMITMODE( cvda)ENABLESTATUS( cvda)INVOKETYPE( cvda)PRIORITY( cvda)PROGRAM( data-area)TRANSACTION( data-area)TRANSMODE( cvda)CHANGEAGENT( cvda)CHANGEAGREL( data-area)CHANGETIME( data-area)CHANGEUSRID( data-area)DEFINESOURCE( data-area)DEFINETIME( data-area)INSTALLAGENT( cvda)INSTALLTIME( data-area)INSTALLUSRID( data-area)
Conditions: END, ILLOGIC, NOTAUTH, NOTFND
This command is threadsafe.
Description
The INQUIRE EPADAPTER command returns information about a specified event processing adapter.
Browsing
You can browse through all the event processing adapters that are installed in your region by using the browse options (START, NEXT, and END) on INQUIRE EPADAPTER commands.
See Browsing resource definitions for general information about browsing, including syntax, exception conditions, and examples.
The resource signature
You can use this command to retrieve the resource signature fields. You can use these fields to manage resources by capturing details of when the resource was defined, installed, and last changed. For more information, see Identifying changes to resources (resource signatures). See Summary of the resource signature field values for detailed information about the content of the resource signature fields.
Options
ADAPTERTYPE(cvda)
Returns a CVDA value indicating the type of this EP adapter. The CVDA values are as follows:
CUSTOM
A user-written EP adapter that emits events in any format that you require to any destination.
HTTP
The HTTP EP adapter that emits events to an HTTP server for consumption by products such as IBM® Operational Decision Manager and IBM Business Monitor.
TDQUEUE
The TDQ EP adapter that emits events to a named CICS® transient data queue.
TRANSTART
The Transaction Start EP adapter that emits events to a named CICS transaction.
TSQUEUE
The TSQ EP adapter that emits events to a named CICS temporary storage queue.
WMQ
The IBM MQ EP adapter that emits events to IBM MQ for consumption by products such as IBM Operational Decision Manager and IBM Business Monitor.
AUTHORITY(cvda)
Returns a CVDA value indicating the authority of the EP adapter. The CVDA values are as follows:
CONTEXT
The EP adapter runs using the user ID of the task that caused the event to be captured. This is always the case when EMITMODE is SYNCHRONOUS or when Use Context User ID is specified in the advanced section of the Adapter tab for the EP adapter.
Default
The EP adapter runs using the CICS default user ID.
REGION
The EP adapter runs using the CICS region user ID.
USERID
The EP adapter is attached using the identifier specified in the EP adapter user ID and returned in the AUTHUSERID attribute.
AUTHUSERID(data-area)
Returns the 8-character identifier to be used to attach the EP adapter transaction. This attribute is only set if AUTHORITY is USERID.
CHANGEAGENT(cvda)
Returns a CVDA value that identifies the agent that made the last change to the resource definition. The possible values are as follows:
CREATESPI
The resource definition was last changed by an EXEC CICS CREATE command.
CSDAPI
The resource definition was last changed by a CEDA transaction or the programmable interface to DFHEDAP.
CSDBATCH
The resource definition was last changed by a DFHCSDUP job.
DREPAPI
The resource definition was last changed by a CICSPlex® SM BAS API command.
CHANGEAGREL(data-area)
Returns a 4-digit number of the CICS release that was running when the resource definition was last changed: for example, 0760 is the identifier for CICS TS for z/OS®, Version 6.3.
CHANGETIME(data-area)
Returns an ABSTIME value that represents the time stamp when the resource definition was last changed. For more information about the format of the ABSTIME value, see FORMATTIME.
CHANGEUSRID(data-area)
Returns the 8-character user ID that ran the change agent.
CONFIGDATA1(data-area)
A 64-character data area containing the primary configuration data item for the EP adapter. If the primary configuration data item is less than 64 bytes, the field is padded with blanks. The data item returned is dependent upon ADAPTERTYPE, as follows:
CUSTOM
Returns the first 64 bytes of custom EP adapter configuration data.
HTTP
Returns the 8-character name of the URIMAP definition to be used by an HTTP EP adapter to locate the HTTP server.
TDQUEUE
Returns the 4-character name of the transient data queue for the event emitted by a TDQ EP adapter.
TRANSTART
Returns the 4-character name of the event consumer transaction that is started by a Transaction Start EP adapter.
TSQUEUE
Returns the 16-character name of the temporary storage queue for the event emitted by a TSQ EP adapter.
WMQ
Returns the 48-character name of the IBM MQ queue for event messages emitted by this IBM MQ EP adapter. This data is in the code page defined by the LOCALCCSID system initialization parameter.
DATAFORMAT(cvda)
Returns a CVDA value indicating the format of events emitted by this EP adapter. The CVDA values are as follows:
USER
The format is user-defined.
CBER
Common Base Event REST format for the IBM Business Monitor REST HTTP server.
CBE
Common Base Event format for consumption by products such as IBM Business Monitor.
CCE
CICS Container Event format.
CFE
CICS Flattened Event format.
DSIE
Decision Server Insights Event format for consumption by the Decision Server Insights component of IBM Operational Decision Manager.
WBE
WebSphere® Business Events (XML) format for consumption by the Decision Server Events component of IBM Operational Decision Manager.
DEFINESOURCE(data-area)
Returns the 8-character source of the resource definition. The DEFINESOURCE value depends on the CHANGEAGENT value. For more information, see Summary of the resource signature field values.
DEFINETIME(data-area)
Returns an ABSTIME value that represents the time stamp when the resource definition was created.
EMITMODE(cvda)
Returns a CVDA value indicating the event emission attribute of this EP adapter. The CVDA values are as follows:
ASYNCHRONOUS
Event emission and the capturing transaction are asynchronous. Failure to emit an event has no effect on the capturing transaction.
SYNCHRONOUS
Event emission is synchronous with the capturing transaction. The unit of work for the capturing transaction does not complete successfully when the event is not emitted.
ENABLESTATUS(cvda)
Returns a CVDA value indicating the status of this EP adapter. CVDA values are as follows:
ENABLED
The EP adapter is enabled.
DISABLED
The EP adapter is disabled.
EPADAPTER(data-area)
Specifies the name (1 - 32 characters) of an EP adapter. You must specify this option to retrieve details of a particular EP adapter by name. On the browse form of this command, you must provide a 32-character data area to receive the name of the EP adapter.
INSTALLAGENT(cvda)
Returns a CVDA value that identifies the agent that installed the resource. Only one value is possible:
BUNDLE
The resource was installed by a bundle deployment.
INSTALLTIME(data-area)
Returns an ABSTIME value that represents the time stamp when the resource was installed.
INSTALLUSRID(data-area)
Returns the 8-character user ID that installed the resource.
INVOKETYPE(cvda)
Returns a CVDA value indicating how the EP adapter is started. The CVDA values are as follows:
ATTACH
The EP adapter is attached as a separate task.
LINK
The EP adapter program is linked to.
PRIORITY(cvda)
Returns a CVDA value indicating the dispatching priority of event emission for this EP adapter. This attribute is ignored when EMITMODE is SYNCHRONOUS. The CVDA values are as follows:
HIGH
Events emitted for this EP adapter are high priority.
NORMAL
Events emitted for this EP adapter are normal priority.
PROGRAM(data-value)
Returns the 8-character name of the EP adapter program. If the ADAPTERTYPE is CUSTOM, this attribute is only applicable if INVOKETYPE is LINK.
TRANSACTION(data-value)
Returns the 4-character name of the transaction definition that is used if the EP adapter transaction is attached. The TRANSACTION attribute is only applicable if INVOKETYPE is ATTACH.
TRANSMODE(cvda)
Returns a CVDA value indicating the event transactionality attribute of this EP adapter. CVDA values are as follows:
NONTRANS
Events are not transactional. Events can be emitted regardless of whether the unit of work for the capturing transaction completes successfully.
TRANS
Events are transactional. Events can be emitted only when the unit of work for the capturing transaction completes successfully.
Conditions
END
RESP2 values:
2
There are no more EP adapters to browse.
ILLOGIC
RESP2 values:
1
You have issued a START command when a browse of this resource type is already in progress, or you have issued a NEXT or an END command when a browse of this resource type is not in progress.
NOTAUTH
RESP2 values:
100
101
The user associated with the issuing task is not authorized to read the EP adapter.
NOTFND
RESP2 values:
3
The specified EP adapter cannot be found.
