INQUIRE ENQ
Retrieve information about enqueues held or waited on by a UOW, or about UOWs holding or waiting on a specified enqueue. INQUIRE ENQ is a synonym for INQUIRE UOWENQ; see INQUIRE UOWENQ for a full description.
Syntax
Conditions: END, ILLOGIC, NOTAUTH, UOWNOTFOUND
NOHANDLE, RESP, and
This command is threadsafe.
