INQUIRE ASSOCIATION
Retrieve association information for a specified task from its association data control block (ADCB).
Syntax
INQUIRE ASSOCIATION
Read syntax diagramSkip visual syntax diagramINQUIRE ASSOCIATION( data-value)options
Options
Read syntax diagramSkip visual syntax diagramACAPPLNAME( data-area)ACMAJORVER( data-area)ACMICROVER( data-area)ACMINORVER( data-area)ACOPERNAME( data-area)ACPLATNAME( data-area)APPLDATA( data-area)APPLID( data-area)CLIENTIPADDR( data-area)CLIENTLOC( data-area)CLIENTPORT( data-area)CLNTIPFAMILY( cvda)DNAME( data-area)FACILNAME( data-area)FACILTYPE( cvda)INITUSERID( data-area)IPCONN( data-area)IPFAMILY( cvda)LUNAME( data-area)MVSIMAGE( data-area)NETID( data-area)ODADPTRID( data-area)ODADPTRDATA1( data-area)ODADPTRDATA2( data-area)ODADPTRDATA3( data-area)ODAPPLID( data-area)ODCLNTIPADDR( data-area)ODCLNTPORT( data-area)ODFACILNAME( data-area)ODFACILTYPE( cvda)ODIPFAMILY( cvda)ODLUNAME( data-area)ODNETID( data-area)ODNETWORKID( data-area)ODSERVERPORT( data-area)ODSTARTTIME( data-area)
Options
Read syntax diagramSkip visual syntax diagramODTASKID( data-area)ODTCPIPS( data-area)ODTRANSID( data-area)ODUSERID( data-area)PHAPPLID( data-area)PHCOUNT( data-area)PHNETWORKID( data-area)PHSTARTTIME( data-area)PHTASKID( data-area)PHTRANSID( data-area)PROGRAM( data-area)PTCOUNT( data-area)PTSTARTTIME( data-area)PTTASKID( data-area)PTTRANSID( data-area)REALM( data-area)SERVERIPADDR( data-area)SERVERPORT( data-area)SRVRIPFAMILY( cvda)STARTTIME( data-area)TCPIPJOB( data-area)TCPIPSERVICE( data-area)TCPIPZONE( data-area)TRNGRPID( data-area)TRANSACTION( data-area)USERCORRDATA( data-area)USERID( data-area)
Conditions: INVREQ, NOTAUTH, TASKIDERR
This command is threadsafe.
Description
The INQUIRE ASSOCIATION command retrieves information about the way a task was started, based on a task number.
Association records are identified by task numbers. Therefore, the input data, specified on the ASSOCIATION option of the INQUIRE command, is the task number. The association data is retrieved from the association data control block (ADCB) of the specified task.
The association data control block is built during task attach processing. It might contain information about another CICS® task that acted as the point of origin for this task.
Use the INQUIRE ASSOCIATION command to inquire about the association data of a single task in the local region. Browsing is not supported.
For more information about association data and origin data, see Association data.
INQUIRE WORKREQUEST is obsolete and is replaced by INQUIRE ASSOCIATION.
Functional equivalents
  • CEMT: Not applicable
  • CICS Explorer®: The Task Associations view provides a functional equivalent to this command.
Options
ACAPPLNAME(data-area)
Returns, in a 64-character area, the name of the application that is associated with the task. If no application context is associated with the task, this option is blank.
ACMAJORVER(data-area)
Returns, in fullword binary form, the major version number of the application associated with the task. If no application context is associated with the task, this option returns 0.
ACMICROVER(data-area)
Returns, in fullword binary form, the micro version number of the application associated with the task. If no application context is associated with the task, this option returns 0.
ACMINORVER(data-area)
Returns, in fullword binary form, the minor version number of the application associated with the task. If no application context is associated with the task, this option returns 0.
ACOPERNAME(data-area)
Returns, in a 64-character area, the name of the application operation that is associated with the task. If no application context is associated with the task, this option is blank.
ACPLATNAME(data-area)
Returns, in a 64-character area, the name of the platform that is associated with the task. If no application context is associated with the task, this option is blank.
APPLDATA(data-area)
Returns the 40-character value of the application data associated by CICS with the socket that received the request that started this task. If the task was not started through a TCPIPSERVICE socket, APPLDATA is blank.
The 40-character application data consists of these bytes:
A 24-byte prefix owned by the Sockets domain
Bytes 01-03
DFH
Byte 04
I
Inbound (listen and accept)
O
Outbound (connect)
Bytes 05-12
The APPLID of this region
Bytes 13-16
The ID of the transaction that is defined in the TCPIPSERVICE:
CIEP
ECI inbound
CISC
IPIC outbound
CISS
IPIC inbound
CWXN
HTTP inbound
CWXU
USER inbound
xxxx
HTTP outbound
Bytes 17-24
The network protocol: one of ECI, HTTP, IPIC, or USER
A 16-byte suffix owned by the using domain
The contents of the suffix depends on the state of the connection:
The TCPIPSERVICE is listening on the socket
Bytes 25-32
The TCPIPSERVICE name
Bytes 33-40
The first 8 bytes of the TCPIPSERVICE description
After the IPCONN has been acquired
Bytes 25-32
The IPCONN name
Bytes 33-40
The APPLID of the partner region
Default for outbound connections
Bytes 25-40
Blank
This data can be used to correlate CICS connection information with z/OS Communication Server connection information.
APPLID(data-area)
Returns the 8-character APPLID of the CICS region in which this task is running.
ASSOCIATION(data-value)
Specifies the 4-byte number of the task for which you want to retrieve association data.
CLIENTIPADDR(data-area)
Returns, into a 39-character area, the IP address of the TCP/IP client that requested this task to start. When the CLNTIPFAMILY option returns IPV4, the returned address is a 15-character dotted decimal IPv4 address, padded with blanks. When CLNTIPFAMILY returns IPV6, the address returned is a 3- to 39-character colon hexadecimal IPv6 address, padded with blanks. If this task was not started from a TCP/IP client, CLIENTIPADDR returns 0.0.0.0 and CLNTIPFAMILY returns NOTAPPLIC.
You can specify IPv4 and IPv6 addresses in a number of acceptable formats. See IP addresses for more information about address formats.
CLIENTLOC(data-area)
Returns a 32-character area that represents the SO_CLUSTERCONNTYPE socket option returned by z/OS Communications Server for the facility in the FACILNAME option. The binary format of SO_CLUSTERCONNTYPE is converted to characters in CLIENTLOC and displayed as either zeros or ones. The CLIENTLOC option represents the current socket, unless the value in the FACILTYPE option is IPIC, in which case CLIENTLOC is taken from the CLIENTLOC value for the IPCONN. For details, see INQUIRE IPCONN. For a description of SO_CLUSTERCONNTYPE and an explanation of the bit settings, see z/OS Communications Server: IP Sockets Application Programming Interface Guide and Reference.
CLIENTPORT(data-area)
Returns, in fullword binary form, the number of the port that the TCP/IP stack used to send the request that resulted in this task being attached. If the task was not started in this way, CLIENTPORT returns zero.
CLNTIPFAMILY(cvda)
Returns a value indicating the form of TCP/IP addressing used by this task. The CVDA values are as follows:
IPV4
The address is specified in IPv4 dotted decimal address format.
IPV6
The address is specified in IPv6 colon hexadecimal address format.
NOTAPPLIC
0.0.0.0 is specified in the CLIENTIPADDR option and the task was not started from a TCP/IP client.
DNAME(data-area)
Returns the 1- to 246-character distinguished name padded with trailing ASCII blanks. Distinguished names are represented in UTF-8 encoding. If a distinguished name is not available for the task, DNAME returns ASCII blanks.
FACILNAME(data-area)
Returns the 8-character name of the facility associated with the initiation of this task. If the facility is a socket, FACILNAME returns the string "**STE**". If the facility is a web request without a URIMAP, FACILNAME returns the string "**WRB**".
FACILTYPE(cvda)
Returns a CVDA value identifying the type of facility that initiated this task. CVDA values are as follows:
APPC
LU 6.2 (APPC) connection
ASRUNTRAN
Asynchronous run transaction
BRIDGE
3270 bridge facility virtual terminal
EVENT
Event processing channel
IIOP
Internet Inter-ORB Protocol
IPECI
IP ECI Client Conversation session
IPIC
IP interconnectivity session (IPCONN)
JVMSERVER
JVM server
LU61
LU 6.1 session
MRO
MRO session
NODEJSAPP
Node.js application
NONE
No facility is associated with this task
RRSUR
Recovery Manager Unit of Recovery
RZINSTOR
Request stream (RZ) instore transport client
SCHEDULER
Scheduler timer request entry
SOCKET
Socket domain session entry
START
Non terminal-related START element
STARTTERM
Terminal-related START element
TERMINAL
Terminal entry
TRANDATA
Transient data destination entry
WEB
CICS web support session
XMRUNTRAN
CICS business transaction services (BTS) activity
INITUSERID(data-area)
This option is no longer supported.
IPCONN(data-area)
Returns the 8-character name of any IPIC connection that was used to receive a request that resulted in this task starting. If the task was not started in this way, IPCONN returns blanks. This field contains a nonblank value only when the FACILTYPE is IPIC.
IPFAMILY(cvda)
Replaced by the SRVRIPFAMILY option, which supports IPv6 addressing. IPFAMILY is maintained for existing programs only. Returns a CVDA value indicating the form of TCP/IP addressing used by this task. CVDA values are as follows:
IPV4
The request that caused CICS to initiate this task arrived at a TCPIPSERVICE resource that used an IPv4 address.
IPV6
The request that caused CICS to initiate this task arrived at a TCPIPSERVICE resource that used an IPv6 address.
NOTAPPLIC
No TCP/IP client is associated with this task.
LUNAME(data-area)
Returns the 8-character network name of the terminal from which this task was started. If the task was started from an IPIC (IPCONN), ISC over SNA (APPC), or MRO session, LUNAME returns the APPLID of the remote region. If the task was not started from a terminal, nor from an IPCONN, APPC, or MRO session, LUNAME returns blanks. For OTS transactions, LUNAME returns blanks.
MVSIMAGE(data-area)
Returns the 8-character name of the MVS image associated with the TCPIPSERVICE used to receive a request that resulted in this task starting. If the task was not started in this way, MVSIMAGE returns blanks.
This function depends on Communication Server TCP/IP Network Access Control support being activated and the CLIENTIPADDRESS being configured into a Network Security Zone.
NETID(data-area)
Returns the 8-character network ID of the terminal from which this task was started.
ODADPTRID(data-area)
Returns, in a 64-character area, the data that was added to the origin data by the adapter. This field is created when the originating task is started. If the task was not started by using an adapter, or if it was and the adapter did not set this value, ODADPTRID returns blanks.
ODADPTRDATA1(data-area)
Returns, in a 64-character area, the data that was added to the origin data by the adapter. This field is created when the originating task is started. If the task was not started by using an adapter, or if it was and the adapter did not set this value, ODADPTRDATA1 returns blanks. ODADPTRDATA1 also returns blanks if the adapter set a value for this field, but did not set an adapter identifier.
ODADPTRDATA2(data-area)
Returns, in a 64-character area, the data that was added to the origin data by the adapter. This field is created when the originating task is started. If the task was not started by using an adapter, or if it was and the adapter did not set this value, ODADPTRDATA2 returns blanks. ODADPTRDATA2 also returns blanks if the adapter set a value for this field, but did not set an adapter identifier.
ODADPTRDATA3(data-area)
Returns, in a 64-character area, the data that was added to the origin data by the adapter. This field is created when the originating task is started. If the task was not started by using an adapter, or if it was and the adapter did not set this value, ODADPTRDATA3 returns blanks. ODADPTRDATA3 also returns blanks if the adapter set a value for this field, but did not set an adapter identifier.
ODAPPLID(data-area)
Returns the 8-character APPLID taken from the origin descriptor associated with this task.
ODCLNTIPADDR(data-area)
Returns, into a 39-character area, the IP address of the TCP/IP client that requested the originating task to start. When ODIPFAMILY returns IPV6, the address returned is a 3- to 39-character colon hexadecimal IPv6 address, padded with blanks. If the originating task was not started from a TCP/IP client, ODCLNTIPADDR returns 0.0.0.0 and ODIPFAMILY returns NOTAPPLIC.
ODCLNTPORT(data-area)
Returns, in fullword binary form, the number of the port that the TCP/IP stack used to send the request that resulted in the originating task being attached. If the originating task was not started in this way, ODCLNTPORT returns zero.
ODFACILNAME(data-area)
If the facility associated with the initiation of the originating task is a transient data queue, a terminal, or a system, ODFACILNAME returns the 8-character name of the facility.
If the facility associated with the initiation of the originating task is a socket, ODFACILNAME returns the string "**STE**".
ODFACILTYPE(cvda)
Returns a CVDA value identifying the type of facility that initiated the originating task that is associated with this task. CVDA values are as follows:
APPC
ASRUNTRAN
BRIDGE
EVENT
IIOP
IPECI
IPIC
JVMSERVER
JVM server
LU61
LU 6.1 session
MRO
MRO session
NODEJSAPP
Node.js application
NONE
RRSUR
RZINSTOR
SCHEDULER
SOCKET
START
STARTTERM
TERMINAL
Terminal entry
TRANDATA
WEB
XMRUNTRAN
ODIPFAMILY(cvda)
Returns a value indicating the form of TCP/IP addressing used by the originating task. CVDA values are as follows:
IPV4
IPV6
NOTAPPLIC
0.0.0.0 is specified in the ODCLNTIPADDR option and the task was not started from a TCP/IP client.
ODLUNAME(data-area)
Returns the 8-character network logical unit name of the terminal from which the originating task was started. If the originating task was started from an IPIC (IPCONN), ISC over SNA (APPC), or MRO session, ODLUNAME returns the network name of the remote region. If the originating task was not started from a terminal, nor from an IPCONN, APPC, or MRO session, ODLUNAME returns blanks. For OTS transactions, ODLUNAME returns blanks.
ODNETID(data-area)
Returns the 8-character network ID of the terminal (terminal, APPC peer, or similar device) from which the originating task was started.
ODNETWORKID(data-area)
Returns the 8-character network qualifier for the origin region APPLID on which the task ran.
ODSERVERPORT(data-area)
Returns, in fullword binary form, the listening IP port number that was used when the originating task received the request. If the originating task was not started in this way, ODSERVERPORT returns zero.
ODSTARTTIME(data-area)
Returns a 21-character representation of the time when the originating task was started. The time is in GMT and in the form yyyymmddhhmmss.ssssss.
ODTASKID(data-area)
Returns the 4-byte packed decimal identifier of the originating task that is associated with this task.
ODTCPIPS(data-area)
Returns the 8-character name of the TCPIPSERVICE resource associated with the connection that received the request that resulted in the originating task starting. If the originating task was not started in this way, ODTCPIPS returns blanks.
ODTRANSID(data-area)
Returns the 4-character name of the transaction under which the originating task ran.
ODUSERID(data-area)
Returns the 8-character user ID under which the originating task ran.
PHAPPLID(data-area)
If the specified task was initiated by a task in another CICS region, this field returns the APPLID of the other CICS region, which is obtained from previous hop data.
If the specified task was initiated by an EXCI job, this field returns the EXCI job name. In this case, PHCOUNT returns a value of 1.
This field returns spaces if the specified task was not initiated in either way.
PHCOUNT(data-area)
If the specified task was initiated by a task in another CICS region, this field returns, in fullword binary form, the number of times there has been a request from one CICS region to another to initiate a task with which this task is associated.
If the specified task was initiated by an EXCI job, this field returns a value of 1. In this case, PHAPPLID returns the EXCI job name.
This field returns zero if the specified task was not initiated in either way.
PHNETWORKID(data-area)
Returns the 8-character network qualifier from previous hop data. If the specified task was initiated by a task in another CICS region, PHNETWORKID contains the network qualifier for the APPLID of the other CICS region or spaces if it was not initiated in this way.
PHSTARTTIME(data-area)
Returns a 21-character representation of the task start time from previous hop data. The time is in GMT and in the form yyyymmddhhmmss.ssssss. If the specified task was initiated by a task in another CICS region, PHSTARTTIME contains the start time of the task in the other CICS region, or spaces if it was not initiated in this way.
PHTASKID(data-area)
If the specified task was initiated by a task in another CICS region, this field returns the 4-byte packed decimal identifier of the task in the other CICS region, which is obtained from previous hop data.
If the specified task was not initiated in this way, this field returns packed decimal zero.
PHTRANSID(data-area)
If the specified task was initiated by a task in another CICS region, this field returns the 4-character transaction name of the task in the other CICS region, which is obtained from previous hop data.
PROGRAM(data-area)
Returns the 8-character name of the first program called by a task running this transaction.
PTCOUNT(data-area)
Returns, in fullword binary form, the number of times there has been a request from a task in the local CICS region to initiate a task in the same CICS region by either a RUN TRANSID or a START command without the TERMID option which this task is associated. PTCOUNT returns zero if there have been no such requests. This is effectively the task depth in the local region when using the RUN TRANSID command or the START command when a new point of origin is not created.
PTSTARTTIME(data-area)
Returns a 21-character representation of the task start time from previous or parent transaction data. The time is in GMT and in the form yyyymmddhhmmss.ssssss. If the specified task was initiated by a task in the same CICS region, PTSTARTTIME contains the start time of the task in the local CICS region, or spaces if it was not initiated in this way.
PTTASKID(data-area)
Returns the 4-byte packed decimal identifier from previous or parent transaction data. If the specified task was initiated by another task in the same CICS region, PTTASKID contains the identifier of the task in the local CICS region, or packed decimal zero if it was not initiated in this way.
PTTRANSID(data-area)
Returns the 4-character name of a transaction from previous or parent transaction data. If the specified task was initiated by another task in the same CICS region, PTTRANSID contains the transaction name of the task in the same CICS region, or spaces if it was not initiated in this way.
REALM(data-area)
Returns the 1- to 255-character realm name in UTF-8 encoding, padded with trailing ASCII blanks. The realm is a component of a distributed identity and defines the region where a security ID applies.
SERVERIPADDR(data-area)
Returns, into a 39-character area, the IP address of the IP service that scheduled this task. When the IPFAMILY option returns IPV4, the returned address is a 15-character dotted decimal IPv4 address, padded with blanks. When SRVRIPFAMILY returns IPV6, it is a 3- to 39-character colon hexadecimal IPv6 address, padded with blanks. If this task was not started by an IP service, SERVERIPADDR returns 0.0.0.0 and SRVRIPFAMILY returns NOTAPPLIC.
Returns, in fullword binary form, the number of the port on which the IP service that received the request that resulted in this task being attached is listening. The service can be a TCPIPSERVICE resource or a Liberty JVM server. If the task was not started in this way, SERVERPORT returns zero.
SRVRIPFAMILY(cvda)
Replaces the IPFAMILY option. SRVRIPFAMILY returns a value indicating the form of IP addressing used by this task. CVDA values are as follows:
IPV4
IPV6
NOTAPPLIC
0.0.0.0 is specified in the SERVERIPADDR option and the task was not started from a TCP/IP client.
Returns a 21-character representation of the time when this task was started. The time is in GMT and in the form yyyymmddhhmmss.ssssss.
TCPIPJOB(data-area)
Returns the 8-character name of the TCP/IP job associated with the connection that received the request that resulted in this task starting. If the task was not started in this way, TCPIPJOB returns blanks.
TCPIPSERVICE(data-area)
Returns the 8-character name of the TCPIPSERVICE resource associated with the connection that received the request that resulted in this task starting. If the task was not started in this way, TCPIPSERVICE returns blanks.
TCPIPZONE(data-area)
Returns the 8-character name of the TCP/IP network security zone, if any, associated with the connection that received the request that resulted in this task starting. If there is no TCP/IP network security zone, or the task was not started in this way, TCPIPZONE returns blanks.
TCPIPZONE depends on Communication Server TCP/IP Network Access Control support being activated and the CLIENTIPADDRESS being configured into a Network Security Zone.
TRNGRPID(data-area)
Returns, in a 28-byte area, a unique identifier that represents the transaction group ID of the originating transaction.
TRANSACTION(data-area)
Returns the 4-character name of the transaction that this task is running.
USERCORRDATA(data-area)
Returns, in a 64-byte area, the user correlator data that was added to the associated data origin descriptor by means of an XAPADMGR global user exit program or by another global user exit program that issued an SET ASSOCIATION USERCORRDATA command. This field is created when the originating task is started. If the global user exit program is not driven at XAPADMGR and if another global user exit program has not issued a SET ASSOCIATION USERCORRDATA, USERCORRDATA returns blanks.
USERID(data-area)
Returns the 8-character user ID associated with this task.
Note: In Liberty, when using the CICS security feature, the user ID is established at a time later than Task attach. The association data user ID value reflects the final user ID value used in secure Liberty transactions.
Conditions
INVREQ
RESP2 values:
2
The command was specified with no arguments.
NOTAUTH
RESP2 values:
100
TASKIDERR
RESP2 values:
1
The task specified on the ASSOCIATION option was not found.
