DISCARD PIPELINE
Remove a PIPELINE definition.
Syntax
DISCARD PIPELINE
Read syntax diagramSkip visual syntax diagramDISCARD PIPELINE( data-value)
Conditions: INVREQ, NOTAUTH, NOTFND
NOHANDLE, RESP, and RESP2 are common options that can be added to all EXEC CICS commands to process error conditions. They are not explicitly included in the command syntax diagram and option descriptions. For information about these common options and EXEC CICS command syntax, see EXEC CICS command format and programming considerations.
This command is threadsafe.
Description
Use the DISCARD PIPELINE to remove an PIPELINE from your CICS® region. The PIPELINE must be disabled before it can be discarded.
You cannot discard a PIPELINE resource that is created by a BUNDLE resource. To discard the pipeline, you must disable and discard the BUNDLE resource.
See Discarding resource definitions for general information about discards.
Options
PIPELINE(data-value)
specifies the 8-character name of the PIPELINE whose definition is to be discarded.
Conditions
INVREQ
RESP2 values:
8
The PIPELINE cannot be discarded because it is not disabled.
22
Delete is in progress for this PIPELINE.
200
The command was executed in a program defined with an EXECUTIONSET value of DPLSUBSET or a program invoked from a remote system by a distributed program link without the SYNCONRETURN option.
300
The resource cannot be discarded because it was installed by a BUNDLE resource.
NOTAUTH
RESP2 values:
100
NOTFND
RESP2 values:
1
The PIPELINE cannot be found
