CSD DEFINE
Create a new resource definition in the CSD.
Syntax
Conditions: CSDERR, DUPRES, INVREQ, LENGERR, LOCKED, NOTAUTH
NOHANDLE, RESP, and
command syntax, see EXEC CICS command format and programming considerations.
Description
The CSD DEFINE command creates a new resource definition on the CSD.
A syncpoint is implicit in CSD DEFINE processing, except when an exception condition is detected early in processing the command. Uncommitted changes to recoverable resources made up to that point in the task are committed if the command is successful, and rolled back if not.
Options
- ATTRIBUTES(data-value)
- Specifies the attributes of the new resource. Code the list of attributes as a single character string.
- ATTRLEN(data-value)
- Specifies the length in bytes of the character string supplied in the ATTRIBUTES option as a fullword binary value.
- GROUP(data-value)
- Specifies the 8-character name of the group containing the resource definition.
- RESID(data-value)
- Specifies the 8-character name of the resource to be defined. Resource names such as TRANSACTION that are only four characters in length must be padded with four blanks and passed in an 8-character field.
- RESTYPE(cvda)
- Specifies the type of resource definition to be defined. CVDA values are the resource type names.
- COMPATMODE(cvda)
- Specifies whether obsolete attributes are allowed in the ATTRIBUTES string for this command. Specify one of the following CVDA values:
- COMPAT
- Obsolete resource attributes are allowed in the ATTRIBUTES string for this command.
- NOCOMPAT
- Obsolete resource attributes are not allowed in the ATTRIBUTES string for this command.
Conditions
- CSDERR
- RESP2 values:
- 1
- The CSD cannot be read.
- 2
- The CSD is read only.
- 3
- The CSD is full.
- 4
- The CSD is being used by another CICS® system and is not configured for sharing
- 5
- Insufficient VSAM strings (CSDSTRNO system initialization parameter value) are available to run the EXEC CICS CSD command.
- DUPRES
- RESP2 values:
- 1
- A resource of this name and type already exists in the specified group.
- 2
- The specified group did not exist but because a list of the same name is already present in the CSD, the group could not be created.
- INVREQ
- RESP2 values:
- 1
- The resource type specified for RESTYPE is not valid.
- 2
- The GROUP option contains one or more characters that are not valid.
- 11
- The value of COMPATMODE is not valid.
- 200
- The command was run in a program defined with an EXECUTIONSET value of DPLSUBSET or in a program invoked from a remote system by a distributed program link without the SYNCONRETURN option.
- n
- The ATTRIBUTES string contains a syntax error or RESID contains a character that is not valid.
- LENGERR
- RESP2 value:
- 1
- The length specified in ATTRLEN is negative.
- LOCKED
- RESP2 values:
- 1
- The specified group is locked to another user.
- 2
- The group is IBM®-protected.
- NOTAUTH
- RESP2 value:
- 100
