CREATE SESSIONS
Add a session group to the CONNECTION definition being created.
Syntax
CREATE SESSIONS
Read syntax diagramSkip visual syntax diagramCREATE SESSIONS(data-value) ATTRIBUTES( data-value)ATTRLEN( data-value)LOGNOLOGLOGMESSAGE( cvda)
CREATE SESSIONS attribute values
Read syntax diagramSkip visual syntax diagramDESCRIPTION( char58)AUTOCONNECT(NO)AUTOCONNECT(ALL)AUTOCONNECT(YES)BUILDCHAIN(YES)BUILDCHAIN(NO)CONNECTION( char4)DISCREQ(NO)DISCREQ(YES)IOAREALEN(0,0)IOAREALEN( 0-32767, 0-32767)MAXIMUM(1,0)MAXIMUM( 0-999, 0-999)MODENAME( char8)NEPCLASS(0)NEPCLASS( 0-255)NETNAMEQ( char8)PROTOCOL(APPC)PROTOCOL(LU61)PROTOCOL(EXCI)RECEIVECOUNT( 1-999)RECEIVEPFX( char2)RECEIVESIZE(4096)RECEIVESIZE( 1-30720)RECOVOPTION(SYSDEFAULT)RECOVOPTION(CLEARCONV)RECOVOPTION(NONE)RECOVOPTION(RELEASESESS)RECOVOPTION(UNCONDREL)RELREQ(NO)RELREQ(YES)SENDCOUNT( 1-999)SENDPFX( char2)SENDSIZE(4096)SENDSIZE( 1-30720)SESSNAME( char4)SESSPRIORITY(0)SESSPRIORITY( 0-255)USERAREALEN(0)USERAREALEN( 0-255)USERID( char8)
Conditions: ILLOGIC, INVREQ, LENGERR, NOTAUTH
NOHANDLE, RESP, and RESP2 are common options that can be added to all EXEC CICS commands to process error conditions. They are not explicitly included in the command syntax diagram and option descriptions. For information about these common options and EXEC CICS command syntax, see EXEC CICS command format and programming considerations.
Note to COBOL programmers: In the preceding syntax, you must use ATTRIBUTES(data-area) instead of ATTRIBUTES(data-value).
Description
The CREATE SESSIONS command installs a SESSIONS definition with the attribute specified on the command. It does not use a resource definition stored in the CSD. You can use it only after issuing the initial CREATE CONNECTION command that defines the attributes of a connection and before the final CREATE CONNECTION COMPLETE (or DISCARD) command that ends the process.
The sessions you define always belong to the current connection, and the name that you specify in the CONNECTION option within your ATTRIBUTES string must match the name of the connection specified in the preceding CREATE CONNECTION command. See CREATE CONNECTION for rules about the order of the commands that build a connection, and Using EXEC CICS CREATE commands to define resources for general rules governing CREATE commands.
The CREATE commands are not audited because their actions are recorded by other messages.
Options
specifies the attributes of the group of SESSIONS being added. The list of attributes must be coded as a single character string using the syntax shown in SESSIONS attributes. See The ATTRIBUTES option for general rules for specifying attributes, and SESSIONS resources for details about specific attributes.
ATTRLEN(data-value)
specifies the length in bytes of the character string supplied in the ATTRIBUTES option, as a halfword binary value. The length may not exceed 32767 bytes.
LOGMESSAGE(cvda)
Specifies whether CICS logs the attributes used for the resource that is created. CVDA values are as follows:
LOG
The resource attributes are logged to the CSDL transient data queue.
NOLOG
The resource attributes are not logged.
specifies the 8-character name of the SESSIONS definition to be added to CONNECTION definition under construction. The name of a sessions group needs to be unique only within the current CONNECTION definition, and the group is always added unless you repeat a session name within a connection. In this case, the last successful SESSIONS definition of the same name is the one that is used.
Conditions
ILLOGIC
RESP2 values:
2
The command cannot be executed because no CREATE CONNECTION ATTRIBUTES command has been issued, or the CONNECTION name specified in the ATTRIBUTES argument of this command does not match the name of the connection assigned in the CREATE CONNECTION command.
INVREQ
RESP2 values:
n
There is a syntax error in the ATTRIBUTES string, or an error occurred during either the discard or resource definition phase of the processing. See RESP2 values for CREATE and CSD commands for information on RESP2 values.
7
The LOGMESSAGE cvda value is not valid.
200
The command was executed in a program defined with an EXECUTIONSET value of DPLSUBSET or a program invoked from a remote system by a distributed program link without the SYNCONRETURN option.
LENGERR
RESP2 values:
1
The length you have specified in ATTRLEN is negative.
NOTAUTH
RESP2 values:
100
102
The user of the transaction issuing the CREATE SESSIONS command is not an authorized surrogate of the user specified in USERID.
