CREATE IPCONN
Define and install an IPCONN in the local CICS® region.
Syntax
Conditions: ILLOGIC, INVREQ, LENGERR, NOTAUTH
NOHANDLE, RESP, and
command syntax, see EXEC CICS command format and programming considerations.
Description
- The TCPIPSERVICE definition named on the TCPIPSERVICE option of this IPCONN definition must also be installed in this region and must specify PROTOCOL(IPIC).
- Corresponding IPCONN and TCPIPSERVICE definitions must be installed
in the remote region. Characteristics of corresponding IPCONN and
TCPIPSERVICE definitions are as follows:
- The HOST option of the IPCONN definition on the remote region must specify this region.
- The PORT option of the IPCONN definition on the remote region must specify the same port number as that specified on the PORTNUMBER option of the local TCPIPSERVICE definition named by this IPCONN.
- The TCPIPSERVICE definition on the remote region (named by the IPCONN definition on the remote region) must specify PROTOCOL(IPIC) and, on its PORTNUMBER option, the same port number as that specified by the PORT option of this IPCONN.
- The REMOTESYSTEM option of the installed PROGRAM definition
- The SYSID option of the EXEC CICS LINK PROGRAM command
- The dynamic routing program
For details of the attributes of IPCONN and TCPIPSERVICE definitions, see IPCONN resources and TCPIPSERVICE resource. For guidance on defining IPIC connections, see Defining IPIC connections .
A syncpoint is implicit in CREATE IPCONN processing, except when an exception condition is detected early in processing the command. Uncommitted changes to recoverable resources made up to that point in the task are committed if the CREATE executes successfully, and rolled back if not.
See Using EXEC CICS CREATE commands to define resources for other general rules governing CREATE commands.
The CREATE commands are not audited because their actions are recorded by other messages.
Options
- ATTRIBUTES(data-value)
- Specifies the attributes of the IPCONN that is being added. The list of attributes must be coded as a single character string using the syntax shown in IPCONN resources. See The ATTRIBUTES option for general rules for specifying attributes, and IPCONN resources for details about specific attributes.
- ATTRLEN(data-value)
- Specifies the length in bytes of the character string supplied in the ATTRIBUTES option, as a halfword binary value. The length must not exceed 32767 bytes.
- IPCONN(data-value)
- Specifies the 8-character name of the connection to the remote system (that is, the name of the IPCONN definition to be created).
- LOGMESSAGE(cvda)
- Specifies whether CICS logs the attributes used for the resource that is created. CVDA values are as follows:
- LOG
- The resource attributes are logged to the CSDL transient data queue.
- NOLOG
- The resource attributes are not logged.
Conditions
- ILLOGIC
- RESP2 values:
- 2
- The command cannot be executed because an earlier CONNECTION or TERMINAL pool definition has not yet been completed.
- INVREQ
- RESP2 values:
- n
- There is a syntax error in the ATTRIBUTES string, or an error occurred during either the discard or resource definition phase of the processing. See RESP2 values for CREATE and CSD commands for information on RESP2 values.
- 7
- The LOGMESSAGE CVDA value is not valid.
- 200
- The command was executed in a program defined with an EXECUTIONSET value of DPLSUBSET, or a program invoked from a remote system by a distributed program link without the SYNCONRETURN option.
- LENGERR
- RESP2 values:
- 1
- The length you have specified in ATTRLEN is negative.
- NOTAUTH
- RESP2 values:
- 100
- 102
- The user associated with the task issuing the CREATE IPCONN command is not an authorized surrogate of the user specified in the SECURITYNAME option.
