INQUIRE FEATUREKEY
Retrieves the value of a feature toggle.
Syntax
INQUIRE FEATUREKEY
Read syntax diagramSkip visual syntax diagram INQUIRE FEATUREKEY( data-value) VALUE( data-area) FILEPATH( data-area)
Conditions: NOTAUTH, NOTFND
Description
The INQUIRE FEATUREKEY command returns the value of the feature toggle with the specified name. Feature toggles are used to enable and set configuration options for toggle-enabled features. You can use INQUIRE FEATUREKEY to inquire the enablement state and configuration settings for any toggle-enabled feature. Supported toggle-enabled features are listed in Feature toggles. Follow the links in the feature list table to locate the information about a specific toggle-enabled feature.
Browsing
You can browse through all the feature toggles that are specified for your region by using the browse options on INQUIRE FEATUREKEY commands: START, NEXT, and END. See Browsing resource definitions for general information about browsing, including syntax, exception conditions, and examples.
Options
FEATUREKEY(data-value)
Specifies the 1- to 255-character name of the feature toggle.
VALUE(data-area)
Returns the 1- to 255-character value of the specified feature toggle.
FILEPATH(data-area)
Returns a 255-character data area containing the path to the feature toggle configuration file that defines the feature toggle setting that is in effect in the CICS® region.
Conditions
NOTAUTH
RESP2 values:
100
NOTFND
RESP2 values:
1
The feature toggle with the specified name does not exist.
5
No feature toggles are defined.
Example
For example, the enablement of the BMS 3270 Intrusion Detection Service is controlled by the feature toggle, com.ibm.cics.bms.ids={true|false}. To inquire whether this feature is toggled on for use in the CICS region, issue the following command:
EXEC CICS INQUIRE FEATUREKEY('com.ibm.cics.bms.ids')
To inquire the configuration options that have been set for this feature, issue the following commands:
EXEC CICS INQUIRE FEATUREKEY('com.ibm.cics.bms.ids.action')
EXEC CICS INQUIRE FEATUREKEY('com.ibm.cics.bms.ids.vtamignore')
