CICSPlex SM API command function code values
The CICSPlex® SM API commands and their numeric function code values are listed.
Table 1 is ordered by command name, and Table 2 is ordered by function code value.
For information about the arguments, see CICSPlex SM API command argument list.
| CICSPlex SM command | Number of arguments | Function Code | OBJECT value in ARG2 |
| ADDRESS | 7 | F016 | No |
| CANCEL | 10 | F002 | No |
| CONNECT | 13 | F003 | No |
| COPY | 11 | F004 | No |
| CREATE | 10 | F005 | Yes |
| DELETE | 7 | F006 | No |
| DISCARD | 7 | F007 | No |
| DISCONNECT | 7 | F008 | No |
| EXPAND | 16 | F021 | No |
| FEEDBACK | 10 | F020 | No |
| FETCH | 10 | F009 | No |
| GET | 7 | F00A | Yes |
| GETDEF | 7 | F017 | Yes |
| GROUP | 12 | F01E | Yes |
| LISTEN | 14 | F018 | No |
| LOCATE | 7 | F00B | No |
| MARK | 7 | F00C | No |
| ORDER | 10 | F00D | No |
| PERFORM OBJECT | 10 | F00F | No |
| PERFORM SET | 10 | F00E | Yes |
| QUALIFY | 7 | F010 | No |
| QUERY | 7 | F011 | No |
| RECEIVE | 7 | F012 | Yes |
| REFRESH | 7 | F019 | No |
| REMOVE | 10 | F013 | Yes |
| SET | 10 | F01A | No |
| SPECIFY FILTER | 11 | F014 | Yes |
| SPECIFY VIEW | 11 | F01B | Yes |
| TERMINATE | 7 | F01C | No |
| TRANSLATE | 13 | F01D | Yes |
| UNMARK | 7 | F015 | No |
| UPDATE | 10 | F01F | Yes |
| Function Code | Number of arguments | CICSPlex SM command | OBJECT value in ARG2 |
| F002 | 10 | CANCEL | No |
| F003 | 13 | CONNECT | No |
| F004 | 11 | COPY | No |
| F005 | 10 | CREATE | Yes |
| F006 | 7 | DELETE | No |
| F007 | 7 | DISCARD | No |
| F008 | 7 | DISCONNECT | No |
| F009 | 10 | FETCH | No |
| F00A | 7 | GET | Yes |
| F00B | 7 | LOCATE | No |
| F00C | 7 | MARK | No |
| F00D | 10 | ORDER | No |
| F00E | 10 | PERFORM SET | Yes |
| F00F | 10 | PERFORM OBJECT | No |
| F010 | 7 | QUALIFY | No |
| F011 | 7 | QUERY | No |
| F012 | 7 | RECEIVE | Yes |
| F013 | 10 | REMOVE | Yes |
| F014 | 11 | SPECIFY FILTER | Yes |
| F015 | 7 | UNMARK | No |
| F016 | 7 | ADDRESS | No |
| F017 | 7 | GETDEF | Yes |
| F018 | 14 | LISTEN | No |
| F019 | 7 | REFRESH | No |
| F01A | 10 | SET | No |
| F01B | 11 | SPECIFY VIEW | Yes |
| F01C | 7 | TERMINATE | No |
| F01D | 13 | TRANSLATE | Yes |
| F01E | 12 | GROUP | Yes |
| F01F | 10 | UPDATE | Yes |
| F020 | 10 | FEEDBACK | No |
| F021 | 16 | EXPAND | No |
