CREATE TSMODEL
Define a model for local, remote, or shared temporary storage queues.
Conditions: INVREQ, LENGERR, NOTAUTH
Description
The CREATE TSMODEL command installs a TSMODEL definition with the attribute specified on the command. It does not use a resource definition stored in the CSD. If there is already a TS model with the name you specify in the local CICS® region, the new definition replaces the old one; if not, the new definition is added.
No two TS models can have the same prefix. An attempt to add or replace a model which would result in there being two models with the same prefix will therefore fail.
A syncpoint is implicit in CREATE TSMODEL processing, except when an exception condition is detected early in processing the command. Uncommitted changes to recoverable resources made up to that point in the task are committed if the CREATE executes successfully, and rolled back if not. See Creating resource definitions for other general rules governing CREATE commands.
Options
- ATTRIBUTES(data-value)
- Specifies
the attributes of the TSMODEL resource definition being added. The
list of attributes must be coded as a single character string using
the syntax shown in TSMODEL attributes.
- For details about specific attributes in this resource definition, see TSMODEL attributes.
- For general rules for specifying attributes, see The ATTRIBUTES option.
- ATTRLEN(data-value)
- Specifies the length in bytes of the character string supplied in the ATTRIBUTES option, as a halfword binary value. The length may not exceed 32767 bytes.
- LOGMESSAGE(cvda)
- Specifies whether CICS logs the attributes used for the resource that is created. CVDA values are as follows:
- LOG
- The resource attributes are logged to the CSDL transient data queue.
- NOLOG
- The resource attributes are not logged.
- TSMODEL(data-value)
- Specifies the 8-character name of the TSMODEL definition to be added to the CICS region.
Conditions
- INVREQ
- RESP2 values:
- n
- There is a syntax error in the ATTRIBUTES string, or an error occurred during either the discard or resource definition phase of the processing. See RESP2 values for CREATE and CSD commands for information on RESP2 values.
- 7
- The LOGMESSAGE cvda value is not valid.
- 200
- The command was executed in a program defined with an EXECUTIONSET value of DPLSUBSET or a program invoked from a remote system by a distributed program link without the SYNCONRETURN option.
- LENGERR
- RESP2 values:
- 1
- The length you have specified in ATTRLEN is negative.
- NOTAUTH
- RESP2 values:
- 100
- 101
- The user associated with the issuing task is not authorized to create a TSMODEL definition with this name.
