What you need to configure your model
You need the credentials and other model details to configure your model in OpenPages®.
Ask your data scientist to give you access to the model and to provide you with the following information:
  • What service you are using for the model.
  • Input field names, and the order in which the model requires them.
  • Sample JSONata that represents the model output.
Other information that you need depends on the service you are using.
