General options
Understand the general options for Ceph Block Devices.
Table 1 lists the different default options for Ceph Block Device configuration.
Table 1. Ceph Block Device general options
Option Description Type Default
rbd_clone_copy_on_read When set to true, copy-on-read cloning is enabled. Boolean false
rbd_concurrent_management_ops The maximum number of concurrent management operations in flight (for example, deleting or resizing an image). Integer 10
rbd_enable_alloc_hint If true, allocation hinting is enabled, and the block device will issue a hint to the OSD back end to indicate the expected size object. Boolean true
rbd_non_blocking_aio If true, Ceph will process block device asynchronous I/O operations from a worker thread to prevent blocking. Boolean true
rbd_op_thread_timeout The timeout (in seconds) for block device operation threads. Integer 60
rbd_op_threads The number of block device operation threads.
Warning: Do not change the default value of rbd_op_threads because setting it to a number higher than 1 might cause data corruption.
Integer 1
rbd_request_timed_out_seconds The number of seconds before a maintenance request times out. Integer 30
rbd_skip_partial_discard If true, the block device will skip zeroing a range when trying to discard a range inside an object. Boolean true
rbd_tracing Set this option to true to enable the Linux Trace Toolkit Next Generation User Space Tracer (LTTng-UST) tracepoints. For more information, see Tracing RADOS Block Device (RBD) Workloads with the RBD Replay Feature within the Red Hat Customer Portal. Boolean false
rbd_validate_names Set this option to true to validate image specifications. Boolean true
rbd_validate_pool Set this option to true to validate empty pools for RBD compatibility. Boolean true
