Block device input and output options
rbd_compression_hint
Description
Hint to send to the OSDs on write operations. If set to compressible
and the OSD bluestore_compression_mode setting is passive, the OSD
attempts to compress data. If set to incompressible and the OSD
bluestore_compression_mode setting is aggressive, the OSD will not
attempt to compress data.
Type
Enum
Required
No
Defaultnone
Valuesnone, compressible, incompressible
rbd_read_from_replica_policy
Description
Policy for determining which OSD receives read operations. If set to
default, each PG’s primary OSD will always be used for read
operations. If set to balance, read operations will be sent to a
randomly selected OSD within the replica set. If set to localize, read
operations will be sent to the closest OSD as determined by the CRUSH
map and the crush_location configuration option, where the
crush_location is denoted using key=value. The key aligns with the
CRUSH map keys.
NOTE: This feature requires the storage cluster to be configured with a minimum compatible OSD release of the latest version of IBM Storage Ceph.
Type
Enum
Required
No
Defaultdefault
Valuesdefault, balance, localize
