Data presentation and analysis
The two major functions of IBM Z IntelliMagic Vision are performance monitoring and analysis, and tracking trends in workload and response time.
Performance monitoring and analysis
Run the IBM Z IntelliMagic Vision daily to ensure that outputs like health charts are accurate and precise.
Note: If you do not use trending reports regularly then you can run IBM Z IntelliMagic Vision only when necessary to investigate specific issues. Retain 7 days of information in the details table while using trending reports.
